Old Aug 07, 2012, 08:24 PM
Everything is Upgradeable.
USA, FL, Gainesville
Joined Aug 2010
Build Log
The Hummbee 150" bluecor 3 piece wing
Well guys, with all the rain in sunny Florida and some time available. I decide to build something similar to the hump wing but some useful things from the queen bee wing. I hope to have her finished in another week or so. Will use carbon fiber arrows on the outer pieces and .021 OD cf for main section to lock on place. Quick release pins will help with transport. Main section has a wingspan of 90" and each other section at 30". Hope to balance her on 2 4s 3200mah packs with a 36mm motor in the back. Here are pictures of the hump and queen bee. Also some of the cut pieces already. Templates have been made in case it does fly good.
postalflyer72 is offline Find More Posts by postalflyer72
Old Aug 07, 2012, 08:25 PM
Joined Aug 2010
Old Aug 07, 2012, 09:15 PM
Joined Aug 2010
I am concerned about this loading in any vehicle. This center piece at 90" is huge. I just didn't want the other pieces to have too much load on them.
Old Aug 08, 2012, 09:18 PM
Joined Aug 2010
More updated pics. Ribs will be 1/2" and not The template ones. Also adding
A thin piece of plywood, sandwiched in the center square.
Old Aug 31, 2012, 01:13 AM
Joined Aug 2010
Finally got a chance to do more work on the wing. Made some mistakes on the sections that detach. Had to redo a few things but happy so far. Motor might be on L bracket or cut dead center.
Old Sep 02, 2012, 06:57 PM
Joined Aug 2010
More updates. Will be under 3lbs by far without electronics. Expected flying
Weight is at 6-7lbs. Thrust is at 9.5lbs thanks to 6s and a nice size prop. Yes there will be a maiden video. Hopefully in one week is maiden.
Old Sep 02, 2012, 07:33 PM
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Hey Postal, I hope I will be there to see the maiden. It should fly great!
Thanks for the link and great seeing you today at SFCC.
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Sep 03, 2012, 06:43 PM
Joined Aug 2010
Before I tape the crap out of it. Paint comes first. Bottom still has painters tape but will be orange, original blue and purple. Lipos have been ordered, 1 servo missing out of 4 ordered. All hitec 81's and 85's. Just need the pusher prop 14x8.5 and all set.
Old Sep 17, 2012, 11:03 PM
Joined Aug 2010
Latest. Still waiting on parts from overseas.
Old Sep 19, 2012, 09:31 PM
Joined Aug 2010
Recent updates. Could use some input on wing tips and have a few prototypes made. Hk order finally came in. Hope to maiden next week.
Old Sep 30, 2012, 03:47 PM
Joined Aug 2010
Maiden wing today. Lesson learned, too much flex in the wing. Looked like a bird. Just cause some Have done it, doesnt mean you will. Haven't given up but, that size on foam is a lot. Will recycle most parts into next project.
Old Oct 09, 2012, 11:53 AM
Air Crash Expert
sawman's Avatar
Louisiana
Joined Oct 2005
Good try. I have been pondering a similar effort, but have to figure out how to stiffen the wing without excessive weight gain.
sawman is offline Find More Posts by sawman
Old Oct 09, 2012, 10:49 PM
Joined Aug 2010
I'm considering aluminum C or L's at full length. I can still add another 2lbs and be 1-1 ratio.
Build Log Flying Wing1 KFm2 Bluecore Wing jjr2001 Foamies (Scratchbuilt) 7 Aug 14, 2012 01:52 PM
Discussion F3B Wings Why are they 2 piece and not 3 piece? soholingo Multi Task F3X 33 Jan 27, 2009 04:58 AM
Sold Gabby 3.2M 3 Piece Wing - Like New (Well... Almost) acampfield Aircraft - Sailplanes (FS/W) 5 Jun 07, 2008 01:12 PM
Found Fuse - F3B/F3F for 3 meter 3-piece wing MarcusT Aircraft - Sailplanes (FS/W) 4 Feb 07, 2006 12:11 PM
Wing hold down block in 3-piece wing. Yochim The Builders Workshop 16 Dec 31, 2002 11:23 AM
