Old Sep 16, 2014, 06:41 PM
Joined Aug 2014
Help!
Tips on how to feed water line back threw transom
Well I was being a good uncle and showing my nephew my lucas oil boat...well left the room for a min and came back and he pulled the water line thru the transom...and I'm having a heck of a time trying to get it back thru...any tips thanks
Jwellmaker977 is offline Find More Posts by Jwellmaker977
Old Sep 16, 2014, 08:10 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
Cut the end at a 45 degree angle, then you can catch the tip to pull it through. Or Make a new hole for a brass tube as a thru hull fitting and fill the old hole
cyberhoops is offline Find More Posts by cyberhoops
Old Sep 17, 2014, 12:29 AM
madracer's Avatar
Joined Aug 2012
If it is a really tight fit use a little Vaseline or silicone oil like shock oil on the silcone hose and feed it through
madracer is offline Find More Posts by madracer
Old Sep 23, 2014, 11:03 AM
Joined Oct 2010
Here is one of my boats. Note the little "exhaust pipe" looking fittings on the transom on either side of the rudder. Very clean and effective. Also makes it easy to pill the hose off from the inside if needed and not have to go through threading it back through.
ScarabChris is offline Find More Posts by ScarabChris
Old Sep 23, 2014, 10:19 PM
Tombsy
Pescador's Avatar
Canada, AB, Calgary
Joined Jan 2009
Feed a piece of fishing line thru, taper the end of the water line and tie it on, it should get you close enough to grap it with forceps.
But on my boats I replace them pretty quick with the epoxied in brass tubes or thru hull fittings already mentioned.
Pescador is offline Find More Posts by Pescador
Old Sep 29, 2014, 02:11 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The big pain you'll find is that you have to go through the hull twice. The inner tub and outer hull have a space between them.
Your best bet is to put a piece of brass tubing through, slide the line onto it and then push it through. That way you'll know for sure it's on the right path.
I would second the suggestion for putting a permanent hard line in place though. Some epoxy and a couple inches of brass tubing will be all you need.
wparsons is offline Find More Posts by wparsons
Discussion Need tips on how to train someone w/ buddybox changosurf Beginner Training Area (Aircraft-Electric) 10 Oct 07, 2014 08:09 PM
Discussion How do you line up your stills shots without a downlink to a screen? Any tips? rcminiman Aerial Photography 5 Jul 23, 2014 10:58 AM
Discussion Need tips on a water proof / resistant quadcopter build sideburn Multirotor Talk 1 Dec 27, 2013 09:48 PM
Discussion How to Buy / Trade & Sell For( New RCG Members ) {RCG Member Feed Back Version} John_G Trader Talk 18 Dec 06, 2013 03:55 PM
Question How secure is all your computer on those " Back up on lines ? " cyclops2 Life, The Universe, and Politics 3 Nov 16, 2013 11:06 AM
