Old May 26, 2013, 12:41 PM
Designing something...
United States, CA, Cameron Park
Joined Jan 2004
Build Log
1.25m Hoten IX
Hi everyone,
I feel very lucky to be cutting and building one of Uwe Heuer's 1.25m Ho IX designs. I've already got most of the parts cut and the picture shows the trail fit of some of the center section parts.
In the end the whole structure will be sheeted and planked with 1/16" balsa. It will be powered by two Wemotec Microfans and two Don's RC Wicked Motors.
Please note that this will not be a very quick build since I've got several other builds going on concurrently plus some travel plans.
Comments and questions are always welcome.
Cheers,
Brian
cpdude is offline Find More Posts by cpdude
Old May 26, 2013, 02:01 PM
Canada
Joined Nov 2000
Great!
Mine has been on hold / in process' for some time now.
Couple of issues I tripped over.
The planform Uwe used was derived from the Revell Kit info.. I believe (?).
It's a wee bit at variance with the Bentley dwgs.
Wing sweep is a bit off... as are most dims.
Clearly not a relevant issue, given how well Uwes' flies :-)
Basically disliking the annoying Siren sounds of the Microfans.
So have been experimenting with the ADH300 motors (same as Don's)
Tried; Aeo/Gws 55 mm 6 blader , Haoye 51mm 7 blade,. DS 10 blader 50 mm.
The Haoye providing most thrust, hitting 550 gm on 4s.. so far..sans siren whine :-)
10 blade unit has best sounds (small difference) but not quite as much thrust as the Haoye..so far
Albeit this using Topband 2815 3500 kv Hobby King Edf motors.
Bit more weight (10 gms) but mo' power than the ADH 300 motors.. as these are bigger/can handle more.
Rewinding may improve (?) on that... haven't gotten there yet
You had bits lasered. Pricey?
Bare is online now Find More Posts by Bare
Old May 26, 2013, 03:14 PM
Joined Jan 2004
I don't know about the exact planform. At this size all difference will be pretty small anyway...and as you say it's not a relevant issue, given how well it flies.
I've never uses the Microfans but it's my understanding that more blades sound "better" than fewer blades.
Yes, the parts have been lasered. Pricey? Yes, the cost of my laser cutter!
Regards,
Brian
Originally Posted by Bare View Post
Great!
Old May 26, 2013, 05:45 PM
Frank Feldhaus's Avatar
Germany, NRW, Hopsten
Joined Jul 2005
Hi Brian,
I built and flew 1,25m Horten IX of Uwe Heuer`s plan. I really love the Horten IX :-)
I am attaching a couple of pics:
http://www.rcgroups.com/forums/showthread.php?t=1052087
Horten IX V3 Specifications:
Weight: 1400gr
EDF: 2 x Wemotec Microfan
2 x Het-rc 240-15 Bl-Motor
Lipo: 3s 4000mAh 30C
ESC: 1x Kontronik 80 6-18 Jazz
Cheers,
Frank
Frank Feldhaus is offline Find More Posts by Frank Feldhaus
Old May 26, 2013, 05:57 PM
Joined Jan 2004
Hi Frank,
One question...don't you guys ever sleep over there. It's got to be either 1 or 2 in the morning.
Very nice build and pictures.
It's interesting that you appear to be running off of one ESC. I've done that with two cd-rom motors before but nothing bigger. How has that worked for you?
Regards,
Brian
Old May 26, 2013, 06:14 PM
Joined Jul 2005
I have holidays. I use the time to get finish my BVM P-80 ready assemble. Since there can be times later :-)
Uwe has since installed the same driver set. This has been going, but you have to consider a lot! The start synchronously must take place in both engines. And the engines have always run in the lower speed range.
Cheers,
Frank
Old May 27, 2013, 01:09 AM
Crazy Cessna Owner
Robbie d's Avatar
Australia, SA, Windsor Gardens
Joined May 2001
*Drools* not another I need to think about :\
Robbie d is offline Find More Posts by Robbie d
Old May 27, 2013, 02:55 PM
Joined Jan 2004
I hear you mate!
Old May 29, 2013, 09:19 PM
Joined Jan 2004
Hey Franks,
Are you using the "rudders" inside the exhaust?
Brian
Old May 29, 2013, 10:06 PM
Crazy Cessna Owner
Robbie d's Avatar
Joined May 2001
Though I do already have fans for this one
The vectors were an interesting idea, and it had to be Uwe that came up with it
Old May 29, 2013, 10:25 PM
Joined Jan 2004
Hey Rob,
You already have the fans. Well...
I've been working on a 3d model in Rhino. My plan is to make the kit more like the 2m Ho XII. Meaning more jigs and more interlocking. I want these things to be easy to build!
Cheers,
Brian
Old May 29, 2013, 11:01 PM
Crazy Cessna Owner
Robbie d's Avatar
Joined May 2001
and carbon spars? pleease
Old May 31, 2013, 06:58 AM
Joined Jul 2005
Originally Posted by cpdude View Post
Hey Franks,
Brian
Hi Brian,
no, I have not installed any rudder in the exhaust.
P.S Mario Buhler with his homemade Horten IX 2.80m ... what a great sound and jet
Horten 229 zweiter Flug (6 min 2 sec)
Cheers,
Frank
Old May 31, 2013, 08:21 AM
Joined Jan 2004
Frank,
Yes, that's a very nice jet sound.
Brian
Old May 31, 2013, 10:52 PM
United States, FL, North Port
Joined Mar 2004
Well... i'm glad mine is done and flying, have fun with this project Brian!
invertmast is online now Find More Posts by invertmast
Build Log Beta build: 1/8th scale Horten Ho-IX V3 Tempest Electric Ducted Fan Jet Talk 305 Sep 13, 2012 07:49 PM
Discussion 1/9 ho ix v3 SilentHunter Nurflügel 13 Jan 25, 2012 11:17 PM
Discussion Seeking horten HO IX plans Al3xand3r Scratchbuilt EDFs 18 Feb 04, 2011 06:59 PM
Discussion Horten IX (Ho 229) book on-line WeekendSailor Flying Wings 5 Nov 21, 2010 09:20 PM
Discussion Chris Golds Ho-IX article EFI May 1998? ohmite Electric Ducted Fan Jet Talk 1 Oct 06, 2009 08:56 PM
