Old Sep 16, 2014, 04:45 PM
Joined Sep 2014
Question
Need advice: Vertical stabilization with dihedral
I'm building a 7ft flying wing with a 4ft non-tapered center section and 1.5ft tapered wing ends with ~12 dihedral. Does anyone know if this kind of dihedral could act as vertical stabs? My preference is to not have vertical stabs mostly for looks but also because of how often I tend to beat them up on rough landings, but of course adding them wouldn't be the end of the world.
Any advice would be greatly appreciated.
Thanks and happy flying
Alex
End_Side_a is offline Find More Posts by End_Side_a
Old Sep 16, 2014, 05:10 PM
Joined Aug 2005
What planform: chevron, plank or forward swept? (Delta not included because of provided dimensions)
Welcome aboard RC Groups!
DT56 is offline Find More Posts by DT56
Old Sep 17, 2014, 10:00 AM
Joined Apr 2013
If the tips aren't very far behind the CG they aren't going to be very effective for yaw stability.
Can you provide a picture?
nuteman is offline Find More Posts by nuteman
Latest blog entry: My youtube channel
Old Sep 17, 2014, 03:40 PM
Joined Sep 2014
These pictures should answer questions of dimension and wing style. What do you think?
thanks
Old Sep 17, 2014, 05:18 PM
cbxer55's Avatar
Somewhere in central Oklahoma
Joined Oct 2007
That being said, I suspect from the appearance of the plane in the pictures, it should do just fine as it is. Doubt it needs any fins since it has no vertical surfaces at all.
cbxer55 is offline Find More Posts by cbxer55
Old Sep 17, 2014, 08:13 PM
buyer of the farm
United States, FL, DeLand
Joined Mar 2009
Looks like a sailplane wing!
Rockin Robbins is online now Find More Posts by Rockin Robbins
Old Sep 18, 2014, 12:34 AM
Fremont, CA
United States, CA, Fremont
Joined Jan 2009
You might have problems with yaw stability and turning. For turning you need some side drag at the back.
Here's what I suggest: Attach a temporary vertical fin to the wing with velcro as shown in the pic. Start flying with the fin about 12" behind the prop. Then gradually reduce the fin distance until you don't like how it handles. If you discover that you don't need the fin, all the better.
You might need twin booms and fins to straddle the prop.
djacob7 is offline Find More Posts by djacob7
Old Sep 18, 2014, 01:16 AM
Joined Apr 2013
Hmm... From the pics looks like you've got mild sweep and the tip sections (with dihedral) will provide plenty of roll stability with some yaw stability (because of the vertical component of side area and because of the sweep). It's likely to be marginal because of the very mild sweep.
Try it out and see if it is controllable (nothing like the empirical proof of a crash ).
If you want to play it safe:
If you swept those tip sections back significantly (like at least another 20 degrees - 30 degrees to be safe) then you'd likely have plenty of yaw stability with no need for additional vertical surfaces.
Or do as djacob7 suggested.
By the way: Nice lookin' plane!
Let us know which option worked out for you.
Old Sep 18, 2014, 05:33 PM
I don't like your altitude
Stupot46's Avatar
Joined Sep 2011
That's more or less a plank.The only one I know of that flew without a central fin had drag rudders.
I seem to recall reading that tip fins aren't very efficient with a plank layout
The prop should provide some stability,might be better if you can set it behind the wing- but that leads to balance/cg issues.
Maybe a touch of reflex?
http://www.rcgroups.com/forums/showp...1&postcount=17
A post from this thread
http://www.rcgroups.com/forums/showthread.php?t=2189598
Stupot46 is offline Find More Posts by Stupot46
Discussion Thinking about dihedral, balance of yaw torques when circling,fin size,roll stability aeronaut999 Modeling Science 88 Mar 02, 2014 10:10 PM
Discussion Bat wing flying with no vertical stabilizer fins. crispy1074 Flying Wings 2 Nov 06, 2013 01:34 PM
Question Advice needed regarding wing incidence, dihedral and ailerons on a profile Cub. WarrrEagle! Foamies (Kits) 6 Mar 05, 2006 01:00 AM
Need advice regarding dihedral angle of wing Alex Slowfly Aerial Photography 20 Nov 07, 2005 03:55 PM
excess dihedral during build -- need advice gingin Hand Launch 3 Jan 10, 2005 07:55 AM
