Old Sep 07, 2014, 04:23 PM
United States, MI, Grand Ledge
Joined Jan 2013
What to use for laying out fuselage skins?
I would like to create a flat pattern for cutting out thin skins for my fuselage. I have 2 formers that are elliptical in shape put each having different major and minor axes. Connecting the 2 formers are a number of longerons, along which the skin panels are cut.
I would like, naturally enough, as inexpensive as possible. I can create .dwg and /or .dxf files but only in @D. I don't currently have any 3D programs. Would prefer Linux compatible, but I do run XP in a VM so that's also doable.
Lastly, I could lay all this out by hand with light cardboard and then pdf it into my computer.
sdad is offline Find More Posts by sdad
Old Sep 07, 2014, 11:42 PM
Denver, CO
Joined Dec 2005
I ended up using Sketchup, and the Flattery plugin. Was a little bit of a pain to get to work, but is free.
http://www.rcgroups.com/forums/showthread.php?t=2135533
Roto Rob is online now Find More Posts by Roto Rob
Old Sep 08, 2014, 04:38 AM
Joined Jan 2013
Thanks. I'll give this a shot, see what happens.
Old Sep 08, 2014, 01:58 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
If you're wanting to do this in CAD, DevFus can help.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Discussion What foam safe spray adhesives to use for lay ups ? Cuboodle Hand Launch 15 May 05, 2014 12:59 PM
Help! Fiberglass Fuselage, Lay-up Schedule hoss4659 The Builders Workshop 3 Nov 13, 2013 12:47 PM
Discussion Lay up for full flying stab type fuselage? SetToGo Composites Fabrication 1 Feb 20, 2007 04:17 AM
Discussion What type of silicone is used for the silicone plugs used in moulding fuselages? Tony D. Composites Fabrication 14 Nov 19, 2006 02:04 PM
