Old Sep 02, 2014, 10:40 AM
United States, OH, North Olmsted
Joined Jul 2011
Help!
fuel tank
Hello,
While I am not a beginner, this is something I have always fretted over! Some instructions guide the builder to mount the tank with the tank center line at the level of the needle valve or slightly below that point. Then, looking at ugly stick plans and other aircraft with an upright mounted motor, the tank's center line is way below that point!! That would surely affect inverted flight mixture settings. I always use muffler pressure to the fuel tank. What is the truth? Thanks. Wayne.
propjok1944 is online now Find More Posts by propjok1944
Old Sep 02, 2014, 10:59 AM
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Its not really that much of a factor as long as you are running pressure into the tank off your muffler. If you are not useing pressure, then i'd try and get it as close to center line as possible.......Gene
gene6029 is offline Find More Posts by gene6029
Old Sep 03, 2014, 06:08 AM
WCB
NC
Joined Aug 2005
I've found tank placement to be more of an issue when the engine is mounted inverted. If the carb is too far below the center line it has a tendency to flood. An upright mount doesn't seem to be as critical.
WCB is offline Find More Posts by WCB
Sold 11 Glow fuel tanks, 5 new and 6 used. Tank stoppers and misc fuel line. $15 shipped jl33fr33 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 29, 2014 04:06 PM
For Sale Fuel Tank Assy/ Air Tube for Fuel Tank (New) - Worldwide FILLIPEAMP2 Aircraft - General - Miscellaneous (FS/W) 0 Apr 08, 2014 07:09 PM
Found Uat fuel tank n over flow tank Speedf16 Aircraft - Fuel - Jets (FS/W) 8 Mar 26, 2014 04:48 AM
For Sale Fuel tank (14 oz) and Fuel valves Pat Mattes Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 18, 2014 03:30 PM
Sold Let's get TANKED... Fuel tanks galore Lbuff1 Aircraft - General - Miscellaneous (FS/W) 1 Jan 01, 2014 10:02 PM
