Old Aug 26, 2014, 06:18 PM
guyfawkes's Avatar
United Kingdom, England, Cheltenham
Joined Oct 2013
OpenLRS UHF system not good range - beeping early
Hi
I bought the orange OpenLRS 1W tx and orange rx for my turnigy 9x and made a 1/2 dipole for the tx side and a 1/2 wave monopole for the rx hoping for amazingly good range.
Did a ground test and although the servos kept moving solidly for about a mile it still starts having the odd beep on my transmitter module when I just fly my plane LOS which was disappointing.
Is it normal for this to beep so early in flight and do you just keep flying, or do I have a problem?
Maybe I did a really bad job making the antennas or the telemetry backlink isn't strong enough... Should I buy some tuned antennas
Thanks a lot
guyfawkes is offline Find More Posts by guyfawkes
Old Aug 27, 2014, 07:15 PM
Australia, WA, Perth
Joined May 2014
The module will beep when there is packet loss from the rx on the plane. The rx on the plane is lower power than the Tx module in your controller so although the Tx is losing packets, the Rx might not be. When I first had my openlrs with the stock antennas I would also get the occasional beep flying LOS. I switched my Tx antenna to a readymaderc semi-rigid dipole and the beeping went away entirely.
twentyfoursyc is offline Find More Posts by twentyfoursyc
Old Aug 28, 2014, 04:52 PM
guyfawkes's Avatar
Joined Oct 2013
Thank you I was wondering if that was the reason as the rx is only about 100mw. Still it would be good to get rid of the beeping and stress by getting that readymaderc dipole, how much did you get it for?
Old Aug 29, 2014, 05:49 AM
Joined Mar 2009
Hi, I made a custom firmware to be able to use two 1W OrangeRX TX in order to create a symetrical link. So far I've gone 12 km with it, but it should allow to go much farther.
(It also works perfectly with APM)
http://www.itluxembourg.lu/site
flipflap is offline Find More Posts by flipflap
Old Aug 29, 2014, 03:35 PM
guyfawkes's Avatar
Joined Oct 2013
That sounds good! I have an APM 2.6 on the plane too
Old Aug 29, 2014, 03:58 PM
Joined Mar 2009
The you've got the perfect profile !
Old Aug 30, 2014, 01:22 AM
Joined May 2014
It's $15 and made a big difference.
http://www.readymaderc.com/store/ind...oducts_id=1615
Discussion HawkEYE openLRS ngTX UHF system receivers & transmitters, using openlrsNG infall FPV Equipment 418 Sep 11, 2014 01:37 AM
For Sale RMILEC TS4047 10CH 2.5W UHF long range systems 433Mhz (for Turnigy 9X/JR) mamut FPV Equipment (FS/W) 0 Nov 11, 2013 02:34 PM
For Sale Danish Aviation Systems (Scherrer) UHF 7-8 Watt AMP V.5 for long range system NEW whosthebaddest FPV Equipment (FS/W) 1 Aug 16, 2013 12:07 PM
For Sale OpenLRS complete UHF(433mhz) system themiddleF FPV Equipment (FS/W) 4 Aug 16, 2013 07:01 AM
