Old Sep 05, 2001, 03:55 AM
broom driver
Barnsley, Gods own Yorkshire, Uk
Joined Mar 2001
Ripmax Alliance anyone flying one ?
I have read the review, seen the box, liked the idea anyone out there who is doing it already what are your thoughts on the model.
Are you using 500AR or 1250scr cells?
Which motor and gearbox are you using?
Have you crashed and how did it take the damage ?
How well does it deal with the wind?
DanC is offline Find More Posts by DanC
Old Sep 05, 2001, 05:36 AM
Southampton Hampshire UK
Joined Dec 2000
HI
Iam using the new cp-1300 cells 10 0f them with a irvine colbolt 400 14t and a 2.5/1 gearbox and 9x6 prop.
this set up works ok but i feal that the pitch speed of the prop is to high so i am going to try lower pitch props.
the model itself flyies well but it can be inproved by copling the elevator to flap.
Paul
paul_potter is offline Find More Posts by paul_potter
Old Sep 05, 2001, 05:42 AM
sav
UK
Joined Jun 2000
danc
I've got my eye one but I'm unsure if It will be to advanced for me. I'm looking for a next plane up from my pico cub , easy pigeon that can handle some wind and do some more advance moves.
I've got a twinstar in mind but I really like the look of the alliance.
sav
sav is offline Find More Posts by sav
Old Sep 05, 2001, 07:51 AM
broom driver
Joined Mar 2001
Paul,
Why 10 cells ? Does the motor need them or do you think 8 cells would be okay for a "stock" 400.
I have not seen anywhere offering to sell the new cp1300 cells would you mind providing an address or contact point for the supplier so I can try some.
How much did you pay for the cells / pack ?
Sav
I started with a teddy then a twinstar and now two twinjets. I found the twinstar to be much more unsettling to fly than the twinjet.
I too am looking for a more aerobatic style model but I am concerned about how well the Alliance would survive a hard impact. It also means I have to much more careful than I am with the twinjets
Old Sep 05, 2001, 09:38 AM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
www.hoellein.com and www.hopf-modelltechnik.de have CP1300/1700 cells.
Haldor is offline Find More Posts by Haldor
Old Sep 05, 2001, 09:51 AM
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Dan,
In the UK, Steve Mettam carries the CP1300 cells;
01270 588921 or smettam@netcentral.co.uk
He made me an 8 cell pack (including Recorded Delivery) for 31. I believe he will also match and zap cells if requested.
tim
tim hooper is online now Find More Posts by tim hooper
Old Sep 06, 2001, 04:20 AM
Joined Dec 2000
Hi I am using 10 cells because the motor i had was realy to higher windinds for a geard set up so the 10 cells was required to get the power up,
i do not think that a standard 400 would do the airfraim justace because it is a verry dragy model, i think that a 480 i a must,
as for the airframes duriblty it is quite esaly damaged aesthetically but is harder to damage to the point of being unflyible,
mine has suevived a stall at 6 feet on to the ground.
Paul
Old Sep 06, 2001, 06:54 AM
sav
UK
Joined Jun 2000
paul
so how does it rate for flyability in terms of learning more advanced moves.
the blurb says intermediate but I have no idea how to rate my self.
is intermidate you only crash when you do something dumb that you should no better or is that advanced
sav
Old Sep 06, 2001, 07:10 AM
Joined Dec 2000
Hi
I would say that if you could do some aero batics allredy you should be able to fly it but make sure you cut down the aliron rate to begin with from the advised, it is quite stable mine will fly hands off, also the stall is fairly gentel and easly recovrebel in about 10-15 feet,
for landing this model needs a nice long aproch to avoid the stall i had when my motor melted on the first flight.
Paul
Superfly? Anyone flying one? Tram Foamies (Kits) 18 Dec 01, 2003 11:23 PM
Aeronaut rafale- anyone flying one??? birdseed Electric Ducted Fan Jet Talk 7 Aug 09, 2002 03:46 AM
Wattage Twin Max (anyone flying one yet?) kansascloud Parkflyers 1 Apr 26, 2002 05:23 PM
Zero, Anyone flying one yet? joystix Parkflyers 15 Mar 29, 2002 05:02 PM
DMA Mad Dog - Anyone flying one ??? Smifta Foamies (Kits) 7 Jul 11, 2001 01:49 AM
