Old Oct 16, 2014, 06:10 AM
Joined Sep 2014
Question
what scaled motor &esc should i used on my 1:8boat.?
what scaled motor &esc should i used on my 1:8 scaled boat.?thank you for advice.
back2earth is offline Find More Posts by back2earth
Old Oct 16, 2014, 09:03 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
A bit more information would be very useful if you want to get any meaningful answers.
What are the dimensions of your 1:8 boat, length, width, weight?
What kind of speed are you looking to get from it? What hull type is it?
bill34207 is online now Find More Posts by bill34207
Latest blog entry: 12 o'clock high 2014
Old Oct 16, 2014, 10:08 AM
United States, NC, Durham
Joined Apr 2011
back2 earth,
If it is a 1/8th scale hydro plane I would think its somewhere between 40 and 50 inches 10 - 20 pounds loaded. If you are going to run it In IMPBA scale events the motor choices are scorpion 4035 or NUE 1527 Kvs ranging from around 800 for 10s to 1250 8s. You will need a quality esc capable of 200 amperes continuous as a minimum. The bigger the better. Advice will only get you so far. Once you have all the basic components you must get out and test the boat making adjustments until she runs as you wish. With these setups your prop ranges will likely fall between 46-55 mm.
Happy Boating
X
Xfactor940 is online now Find More Posts by Xfactor940
Old Oct 17, 2014, 05:52 AM
Joined Sep 2014
hi ,back2earth.dirst of all ,is this your first time to play with the boat?
Laurnet is offline Find More Posts by Laurnet
Old Oct 17, 2014, 06:12 AM
Joined Sep 2014
add my facebook name:Lixlie
LUcaus87 is offline Find More Posts by LUcaus87
Old Nov 08, 2014, 12:21 AM
Joined Sep 2014
ok. I added you just now.
Old Nov 08, 2014, 03:24 AM
Joined Sep 2014
Hi@bill34207,my boat is Tenshock MINI ECO,
Old Nov 08, 2014, 03:26 AM
Joined Sep 2014
hiXfactor940;,very thank you for your answer.what boats you used?
Originally Posted by Xfactor940 View Post
back2 earth,
Happy Boating
X
Old Nov 08, 2014, 05:57 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I'm not really familiar with the mini eco boats. I was thinking by 1:8 you were referring to a large hull. There is a fairly active thread on the mini eco here on RC Groups though. http://www.rcgroups.com/forums/showthread.php?t=1865236
Old Nov 08, 2014, 10:07 AM
Joined Sep 2014
Hei!guys,did you also play rc boat?
i'm not really familiar with the mini eco boats. I was thinking by 1:8 you were referring to a large hull. There is a fairly active thread on the mini eco here on rc groups though. http://www.rcgroups.com/forums/showthread.php?t=1865236
Old Nov 08, 2014, 10:19 AM
Joined Apr 2011
What boat I use?
LOL did someone tell you I didnt have one? wouldnt surprise me.... someoenes always talking about what they think they know.........
I run an 1/8th scale'90 circus circus "pink lady" Its 43 inches and 14 pounds loaded . Im currently fitting it with an autonomous canard system........
I as the other poster thought you were speaking of an 1/8th scale unlimited hydroplane......
I dont run any of that submerged stuff not enough excitement there for me without a rooster tail.....
Happy boating
Hugh
Old Nov 12, 2014, 05:46 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
I guess you could say that I do. http://www.wfmbc.com/WFMBC/Projects.html
Old Nov 13, 2014, 12:15 AM
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Hey Bill, you still got your 47 inch mono?
scorpion1 is offline Find More Posts by scorpion1
Old Nov 13, 2014, 05:22 AM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
Yep. Still have it although I don't bring it out as often as I used to.
Discussion What motor combo should I use for my TBS DISCO!! Noah410 Multirotor Power Systems 3 Jul 20, 2014 09:14 PM
Discussion What motor should I order which I can use on most of my foamies...? joy4u Electric Motor Design and Construction 6 Aug 02, 2010 04:46 PM
Discussion What motor should I order which I can use on most of my foamies...? joy4u Foamies (Scratchbuilt) 14 Jul 22, 2010 09:33 AM
Discussion What size of prop should be used w/ brushed 350 motor on my Slow-stick? kfc2 Parkflyers 10 Aug 12, 2008 08:01 PM
Question What ESC timing should I use for my KoraTOP motor? Giz Power Systems 6 Jun 13, 2007 07:13 AM
