Old Jul 01, 2016, 11:18 AM
pogoed is offline
Find More Posts by pogoed
pogoed's Avatar
Waterford, ON, Canada
Joined Nov 2007
WEMOTEC still in business?
I ordered a 90mm EVO rotor direct from WEMOTEC over a month ago as Efflux and Extreme are both out of stock and the order still shows as "in process". Emails sent via the contact page just come back with what I've written and nothing else- helluva way to run a business. Does anyone know what's going on with this company? Jetfan here I come....
Tom
pogoed is offline Find More Posts by pogoed
Old Jul 01, 2016, 01:34 PM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Not helpful, to be certain......but it has been this way for the better part of 2 years.
Occasionally, there are signs of life from there followed by extended periods of silence.
JetFan is an improvement anyway. The Evo is a wonderful piece but the JF is excellent.
And available. With support from Rainer and his crew. Tough act to follow.
PikeStaff is offline Find More Posts by PikeStaff
Old Jul 01, 2016, 03:43 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Nothing out t there compares to a JF ..
Rainer did it right Got a few 90's and a 120mm--- but for the big boys --Dynamax all the way.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jul 02, 2016, 05:06 AM
Kwahn is offline
Find More Posts by Kwahn
Germany
Joined Jul 2010
I always found Oliver's customer service excellent, he answers the phone himself most of the time.
011 - 49 - 2154 - 48 24 77
Should work from the US.
Kwahn is offline Find More Posts by Kwahn
Old Jul 02, 2016, 07:16 AM
pogoed is offline
pogoed's Avatar
Joined Nov 2007
Kwahn, thanks- I'll try calling Monday.
Tom
Old Jul 02, 2016, 07:22 AM
pogoed is offline
pogoed's Avatar
Joined Nov 2007
Mark, I've had these Evo's in several models for a few years now so it is what it is- your comments aren't really helpful. How are you making out with your systems- got anything spun up yet?
Tom
Old Jul 02, 2016, 11:27 AM
Joined Dec 2008
The 90's run sweet- no balancing , didn't even have to clock the spinner.
Old Jul 03, 2016, 04:09 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I can go back to 1996, and EJF waiting for a shipment of Mini/Midi fans. I waited for several months for Robert to get his complete order from Oliver. But, thats just the way it has always been. I learned my lesson, that when they come, they come in quantity. So buy several for future use.
I never owned a JF. Mostly because I fly 70mm or smaller stuff. But, the price may be prohibitive for me, should they ever produce a 70mm. To compare the quality of the two, is just apples and oranges. The WeMo has always been the leader, if you use the bang-for-the-buck, principal.
In another 20years, if Oliver is still in bizz, and if the powers, that be, have not regulated us modelers into non-existance, I do not believe WeMo will ever change. Have patience, and buy two! Get extra rotors, adapters, etc. Then, like myself, you will not notice when they have their scarcity periods.
Anytime I need a fan from 64mm-69mm, I can assemble a fan from my WeMo box.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jul 04, 2016, 04:24 PM
pogoed is offline
pogoed's Avatar
Joined Nov 2007
Fuzz, thanks for the reply- I hear what you're saying but I'm finding this lack of communication (not to mention parts) frustrating. I became a Wemo user about 7 yrs. ago but I think I'm gone.
Tom
Old Jul 04, 2016, 05:44 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Hi Tom
I've been using the FW 6 blade version as a wemo midifan clone with some success for those planes that I want a higher pitch sound (for those fliers hard of hearing). Haven't seen any evo type clones yet...
4stripes is offline Find More Posts by 4stripes
Old Jul 04, 2016, 06:22 PM
HellHathNoFury is online now
Find More Posts by HellHathNoFury
Joined Dec 2013
I too am a Wemo Evo convert preferring the grub screw lockdown shaft & bang for your buck fan which one can install into most shrouds .. Because of the availability of Wemos I normally order spares to get value from freight especially living Down Under... The Lander/Dr Mad 5bl is also another Wemo clone which is very good ... Had a 70mm Lander for years which has had several homes .. Currently in the Yak 130... Great balanced unit & sounds very nice with that high pitch note especially with a cheater ..
HellHathNoFury is online now Find More Posts by HellHathNoFury
Old Jul 04, 2016, 06:55 PM
pogoed is offline
pogoed's Avatar
Joined Nov 2007
Originally Posted by 4stripes View Post
Hi Tom
Hi Eric- I'm not really looking for an Evo clone as I'm happy with the sound and efficiency, but this parts thing is frustrating. The old Wemo 5 blade rotor is available but I'd be going backwards. (Hearing is ok- so far )
BTW, does anyone know if a Jetfan rotor will fit in a V2 Wemo shroud ? (I believe it will but would like confirmation ).
Tom
Old Jul 04, 2016, 08:22 PM
Joined Dec 2013
Tom
Not unless you can get a Eco JF ( cut 1mm shorter) ... I believe JF stopped making those...Bummer because it made it much more economical to install to most shrouds... Stock JF will not fit ..Another reason why I swapped over to Wemo Evos..I have plenty of assorted strong plastic shrouds..
Old Jul 04, 2016, 08:47 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
It's important to note, that WeMo fans are of older size clarification. Same with the HET. They were designed in the 69 & 89mm days. The 70mm is the latest clasification in the last 10 yrs. The 70mm EVO/Pro/Classic is 69mm I.D., 71mm O.D. shroud. 68mm Rotor. The Midi EVO/Pro/Classic is 89mm I.D., 92MM O.D. WeMo has not changed the shrouds in 20yrs. The rotor types are designed to be with all sized Wemo shrouds.
I have had issues with some of the WeMo shrouds(my first WeMo in 1996 had bent mounting lugs!). It's not easy to get exact clearances 360deg. So, I make my own. 2 lams of 1/64 ply for the 69mm, 3 lams for the 89mm. Very easy to make and as ridged as a CF shroud. Have been making my own for atleast 10 yrs. And I can keep the clearances tighter than a stock shroud.
So most shrouds are just used for the stator assemblies. So mostly, I purchase just rotors.
Fuzz
Old Jul 05, 2016, 01:13 AM
dusmmdb34 is offline
Find More Posts by dusmmdb34
dusmmdb34's Avatar
Alexandria LA
Are EVO conversion kits for the midifans available anywhere??!
dusmmdb34 is offline Find More Posts by dusmmdb34
Discussion Lanxiang, still in businesses? Mankan Electric Plane Talk 13 Mar 27, 2016 06:08 AM
Discussion IS bp HOBBIES STILL IN BUSINESS rhd100 Electric Plane Talk 9 Feb 27, 2016 06:35 AM
Discussion Wright Brothers RC - (Still In business ?) Thermalin Sailplane Talk 2 Dec 26, 2015 10:26 AM
Discussion Shred RC - Are they still in business? Robert Rent Hand Launch 10 Dec 01, 2015 12:13 AM
Question Is Home Port Models Still in Business George Jure Scale Boats 4 Sep 18, 2015 06:21 PM
