Old Nov 20, 2015, 03:21 PM
DavidDavidson is offline
Find More Posts by DavidDavidson
Joined Sep 2015
Fitting the metal head from the XK K120 to the XK K110 issues
It turns out that in terms of the rotor gear that many of the parts for the K120 are interchangable with the K110 (for example my k110 had a crash and since the gear, which is held on by friction (no screws at all, just friction alone and the circular rotor head made into a semicircle so the gear wouldn't spin when power was put to it.
However I've discovered that since I have plenty of XK 120 spares including the main gear I put the main shaft from a k120 into the K110, fitted a gear for the K120 and it was fine. I fitted the metal rotor head, swash and everything else which is also apparently interchangeable and this is where I ran into issues. In 6g mode the servos would react fine, however on take-off the heli kept flying to the right side. Since I was indoors I wasn't trying to fly high and no damage was done to the heli. I recalibrated the gyro and tried again. It kept leaning to the right and would only fly if I gave full left ailereon, there were no servo issues and all of them worked fine at changing blade pitch, it was like the gyro couldn't fight it.
I changed back to plastic (which is about 15 minutes work and hovered using the same gyro settings, the helicopter flew fine.
Any ideas on why it would do that? I'm completely stumped.
Edit:
I separated the metal swashplate from the heli and it seems to be flying fine now. Although it seems to want to go forward no matter what I tell it and I can't get it into a stable 6g hover, though this was also a problem with the no fisheye, plastic swash.
DavidDavidson is offline Find More Posts by DavidDavidson
Old Nov 20, 2015, 06:12 PM
dadio is offline
Find More Posts by dadio
United Kingdom, Surrey
Joined Jan 2013
Are the ball joints nice and free moving on the servo to swash links ? If they are even a little bit tight it will cause it to be virtually unflyable ,I was thinking you had possibly used the k110 servo rods and the balls on the k120 swash might be slightly bigger causing them to bind ?
dadio is offline Find More Posts by dadio
Old Nov 21, 2015, 04:54 PM
Joined Sep 2015
I've actually removed and attached the fisheye swash from the metal head and put it on the 110. The heli keeps flying forward and my backward pitch is almost maxxed out though I'm not sure if that's the swash or the bigger batteries making it front heavy. I'm having trouble getting it to hover though it's winter and very windy so I can't really go outside and trim it and I honestly think it's a trimming issue as I can get it to hover in a 1.5-2' space, but only with stick input though I had the same issue with the 110 swash (but had less manoeuvrable because no fisheye and an overall cheaper bearing setup
I would like to mention that anyone who owns an 110 they should buy 120 main shafts and gears. Totally interchangeable and the main gear actually screws on (I lost my first main gear in a hard landing because I didn't know that they were just pushed on and held in place by friction) since the motor on the 120 is more powerful the gears are tougher and don't seem to strip like the girl you hired to the stag party upon the slightest contact with something
I saw the heli lean to the right and had to reset the gyro so it may be gyro related, though I'm happy enough with plastic grips, it was mostly the swash plate I wanted. I'll see if I can get some graphite lubricant and make the connections a little more slippery as when I do get a hover it seems to suffer from some sort of toilet bowl effect, which I think is due to the connections that aren't overtight being just a little too tight and thus are slower than normal to respond to input.
Anyway I have a BNF 120 on DHL mail (just got picked up in china) so it should be here in a couple of weeks. I had one but it caused the servos to cook themselves due to a faulty distribution board, the site I bought it off offered me replacment servos and a distribution board but since; don't ask me why they they thought this was wise, it seems on the 120 the designers haven't yet discovered screws yes that's right the servo distribution board is hot glued to the frame but the kicker is the fact that the servos have no screws holding them together. What holds them together is the 'decorative' stickers on the sides of the servos.
Anyway we agreed that instead of painstakingly gluing the thing together I could get a new BNF half price, which I agreed to since I have a bunch of spares.
Mini-Review XK K110 3G/6G Small CP Heli thread - same or better than V977? (Work in Progress) SoloProFan Micro Helis 654 Today 05:41 PM
New Product XK K120 Shuttle 6CH Brushless 3D6G System RC Helicopter Whitehouse Electric Heli Talk 7 Jul 11, 2016 02:42 PM
New Product XK Blast K110 - Very Nice 3D Micro Heli robson_silva Micro Helis 1 Sep 19, 2015 12:19 PM
Discussion Xk k120 zzc Micro Helis 2 Jul 04, 2015 03:36 AM
