Old Feb 10, 2004, 08:42 PM
n111kx is offline
Find More Posts by n111kx
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
Need some advice on making my Mega scream...
I completed my 75% Ridge Runt, converted for speed to spice things up in the fleet. I figured that my Mega 3 turn would be the ticket as I have run one on NiMh 1700's with great results. Here, the Runt is smaller so I went with a 7 cell 1100 NiMh pack and it was, in a word, wimpy. I thought that it needed another cell so I tried the 8 cell version. Still wimpy compared to the 1700 pack. Also, the packs have been cycled 3 times so far. What do I nned to make this thing move and not have to install a 1700 brick in my Runt?
Thanks in advance...
Kip
n111kx is offline Find More Posts by n111kx
Old Feb 10, 2004, 09:20 PM
schoey is offline
Find More Posts by schoey
schoey's Avatar
Newcastle, Australia
Joined Nov 2000
What prop are you running, we need to know a current draw, that may be the problem with those little nimhs
Grant
schoey is offline Find More Posts by schoey
Old Feb 10, 2004, 09:26 PM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
I've had the Graupner 4.75 and 5.2 speed props on. I'll get with my friend with the amp-meter. Yeah, it's the AA's vs. the 2/3 AA's also...
Kip
Old Feb 10, 2004, 09:27 PM
schoey is offline
schoey's Avatar
Joined Nov 2000
Kip,
Just had a quick look around and I can't see those packs providing much more than 10-15A, a 3 turn mega will want a bit more than that, say 20-25A if proped for high performance. So maybe try the 1700's
Grant
PS I've never owned a nimh pack so I may be wrong.
Old Feb 10, 2004, 10:24 PM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
Grant, is it the norm to run such large batts in small racer-types? I'll gladly trade weight for duration here. My 1700's will run for 6-7 minutes. The same rpm for 3-4 minutes would be ideal.
Kip
Old Feb 11, 2004, 07:14 AM
Kyri is offline
Find More Posts by Kyri
Kyri's Avatar
England
Joined May 2000
I use the 3 turn with a 4.75x4.75 prop on 10 x CP1300's and the current draw on the ground is around 32-34 amps. I get just over 3 minutes full throttle. Its about the limit for the mega, if you ran any higher capacity cells for longer than that you will fry it.
Regards
Kyri
Kyri is offline Find More Posts by Kyri
Old Feb 11, 2004, 07:19 AM
RocketRob is offline
Find More Posts by RocketRob
Size Matters!
RocketRob's Avatar
San Francisco Bay Area
Joined Dec 2002
8-9 1700 aup's run a 3t with a 5.2x5.2 right at 30 amps --perfect!
RocketRob is offline Find More Posts by RocketRob
Old Feb 11, 2004, 08:57 AM
BEA flyer is offline
Find More Posts by BEA flyer
Concord, MA
Joined Jun 2002
You are running HE 1100 cells at way over what they are capable of ampere output wise. Get some better batteries. Try the KAN1050 or 1300 ones. The HE will put out less amps, and you want ampos if you want performance, not just milliamp-hours. The KAN 1050 maybe good for 15 continuous and the 1300 are aa sized 1 oz and maybe 20 amps continuous. The CP1300 nicads would be a good choice or the 1700AUP which are maybe good for 25-30 amps and a little over an ounce each.
These guys who are telling you to keep the weight down are being unrealistic. If you want to go fast, a high wing loading is not such a bad thing.
BEA flyer is offline Find More Posts by BEA flyer
Old Feb 11, 2004, 05:24 PM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
Thanks BEA flyer and everyone else. A friend of mine has some KANs to try...
Kip
http://www.springeraviation.net/
Old Feb 12, 2004, 02:22 PM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
I have 4 mega 3 turn (3 more to come) all on 3S lipo.
3S2P Irate 1100 and 4.7*4.2 is a very fast setup and not that expensive. Obviously, very light. You will not recognize your plane....
luc is offline Find More Posts by luc
Old Feb 12, 2004, 02:35 PM
daking is offline
Find More Posts by daking
PRO BRO #157
daking's Avatar
Sterling hts, Michigan
Joined Jun 2003
I am running my 3 turn on 3s2p kok 1500. About 7.5 oz's for the pack. Give's 6 min's of motor and 300watt's.
daking is offline Find More Posts by daking
Old Feb 12, 2004, 02:36 PM
Yogi is offline
Find More Posts by Yogi
BiggerBetterFasterMORE!!!
Yogi's Avatar
Atlanta Hartsfield, Georgia, United States
Joined Apr 2002
Where are you?
is that the Atlanta EFlyer's field? It looks big and grassy. I need to come fly with you guys. Do tell.
I think the smallest battery that will run that 3 turn well will be the 1700 AUP NiMh, or the 1950 FAUPs . Kan950/1050 will be good for at the max about 16 amps. I don't imagine that you would pull much more than that in the air though. On the ground will be much more. Get a good flight time measurement with your 1700's for a full throttle flight, and calculate your inflight amp draw based on how much you take out of the packs. You'll be surprised how low it may be. The KANs may just be enough.
~~fred francis
Yogi is offline Find More Posts by Yogi
Old Feb 12, 2004, 02:42 PM
jaywatay is offline
Find More Posts by jaywatay
electron liberator
jaywatay's Avatar
United States, GA, Suwanee
Joined Mar 2003
luc, do you know what the amp draw is on that setup?
jaywatay is offline Find More Posts by jaywatay
Old Feb 12, 2004, 02:44 PM
luc is offline
luc
luc
luc's Avatar
France
Joined Feb 2000
around 25A static, 250W....I can't draw more on these cells. I have hotter setups (3S4P kok340 with 4.7*4.7 at close to 340W), but that's an expensive setup
Old Feb 12, 2004, 08:06 PM
n111kx is offline
EXPERIMENTAL
n111kx's Avatar
Atlanta
Joined Nov 2002
Sorry, the field is the ATL RC Club. The "e" flyers fly wherever they will not be thrown out of...
Kip
Need some advice on a Forward Swept Wing ke6guj Slope 16 Dec 22, 2002 11:13 PM
Some advice on using my lovely new Kokam 1020 cells nigel99 Batteries and Chargers 8 Dec 01, 2002 09:44 PM
Need some advice on my Ugly Bird(Pterodactyl)!! Electriflight Foamies (Kits) 9 Sep 02, 2002 08:06 AM
Got my Zero! Need some advice on Rx and battery pack cfossa Parkflyers 0 Apr 01, 2002 10:37 PM
Need some advice on power tool The_Giver Life, The Universe, and Politics 0 Nov 30, 2001 01:52 PM
