Old Nov 25, 2012, 03:45 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
Possible dual vTx setup on plane, comments please
So i was out flying today with my goggles and i ran into a slight problem, which i'm sure many of you have, so i'll describe it.
I have a bixler with a 500mw 5.8ghz tx, and a cloverleaf, on my goggles i'm using a skew planar wheel antenna.
When i fly, i tend not to go out very far, I just like to get altitude, and a nice view of the area, so my LOS angle to the plane tends to be past 45 degrees (vertical), today it hit close to 70 degrees, as i got up to over 600m. Of course at this point i'm starting to hit the dead zones in the antennae, since they are both situated vertically.
Now i dealt with this by flying out a little further, and banking the plane to re-establish my video signal (i never lost it for more than a second, but i got a lot of static other times when i got that high).
My question is this, i have 2 possible ways of dealing with this:
1. use the existing setup but point the antennae sideways, so my null axis would be horizontal, not vertical, and as i gain altitude (yet not straying far from field) my signal should stay in the sweet spot.
2. Setup 2 video transmitters on the plane, on different channels (as far apart as i can get on an 8 channel 5.8ghz), one with a cloverleaf oriented vertically, the other horizontally. The ground station would have 2 receivers, and each would be paired to the appropriate video tx with SPWs (one video tx + one receiver would be on same channel with vertically oriented antennas, for horizontal distance, the other pair on another channel with horizontally oriented antennae, for vertical distance). I'd hook in the receivers through a diversity (i have one spare) and feed the video in to the goggles.
Thoughts? I'm not looking for super long ranges, just the ability to be as omni as possible without losing signal and soiling myself when my plane is 600m above me.
I curious if anyone has tried this, or if there is some limiting factor that i am completely missing. This would be mounted on a super sky surfer.
CrashAffinity is offline Find More Posts by CrashAffinity
Old Nov 25, 2012, 10:39 PM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
I would try a small helix pointed in the general direction of your plane (can you find a 3-3.5 turn?). Use diversity and see how it works out. I rarely fly in this zone but imagine if I spent most of my time there it (static) would get annoying.
I would definitely try putting the antenna on its side before buying anything though.
I wish I had something useful to tell you about using 2 vtx, but unfortunately I have no clue...
chemnut842 is offline Find More Posts by chemnut842
Old Nov 26, 2012, 11:10 AM
Canada, AB, Calgary
Joined Nov 2012
I may try the antennae on the side first since i'm most going to be circling up and over me as i gain altitude, i have enough parts coming in that i'll be able to try what i suggested, though a diversity with SPW + the helix pointed straight up might work too, i'll post back once i try it anyways.
I don't have a working antenna tracker yet, that would be the ideal solution of course
Old Nov 26, 2012, 11:18 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
You don't need two vTxs, just two antennas is enough. I'm not sure anyone ever tried to mount a dual antenna on a vTx that normally only supports one though.
PHMX is offline Find More Posts by PHMX
Old Nov 26, 2012, 12:10 PM
mich75 is offline
Find More Posts by mich75
Joined Dec 2010
Sircana tested a dual vtx setup using left and right polarised cloverleafs, worked quite nicely apparently.
http://fpvlab.com/forums/showthread....ultimate+video
mich75 is offline Find More Posts by mich75
Old Nov 26, 2012, 12:16 PM
Vintabilly_NS is offline
Find More Posts by Vintabilly_NS
..in a Johnny Cash voice.
Vintabilly_NS's Avatar
Canada, NS, Beaver Bank
Joined Aug 2010
Whoa, that's a lot of work. Turn your antennas sideways, they are cp so they won't be out of phase just out of the null zone. DO IT!
Vintabilly_NS is offline Find More Posts by Vintabilly_NS
Old Nov 26, 2012, 01:28 PM
Canada, AB, Calgary
Joined Nov 2012
yeah i just saw that thanks, i think for now i'll keep it simple for the next flight and just flip the antennas sideways, because it'll take me all of 1 minute to do =)
I'll keep the fancy stuff that leads to tears for next month possibly
Help! Fatshark aviator + 1.3ghz external vtx possible? Crazy1 FPV Talk 2 Nov 23, 2012 06:14 AM
Discussion Reversing ailerons with dual aileron setup on DX6i ejohn Radios 3 Oct 01, 2012 11:03 AM
Discussion Dual vTx on the same platform will be there any problem redblur FPV Talk 5 Sep 05, 2012 12:51 PM
Discussion Comments and questions on my dual tail motor install...CP2 ericnord Micro Helis 7 Apr 23, 2006 07:24 PM
any comments on my corona setup? serious_sam Electric Heli Talk 0 Apr 05, 2002 05:09 PM
