Old Apr 14, 2012, 07:13 PM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
Lipo charge rate question.
I have some new 4s 2200mah 40-50c Turnigy batteries. My question is what charge rate can they safely handle?
Charger is a Tenergy TB6B balance charger. I can select charge amperage by the 10th of the amp.
Seems to me a battery which can discharge at 40a could charge higher than 1 or 2... regardless of the setting the charger will finish the battery at a very reduced leveling phase.
What's the rules of thumb here?
Thank you for any input.
scootrb4 is offline Find More Posts by scootrb4
Old Apr 14, 2012, 07:17 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Per Hobbyking, the Turnigy 40C packs can be safely charged at up to 5C. For your particular pack, this would be 11 amps, which is likely well beyond the maximum capability of your charger for a 4S pack.
I would suggest somewhere between 1-3C (2.2-6.6A) if you're not in a big hurry. Also recommend that you always charge with balance lead attached, whether performing balance charge or not.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 14, 2012, 07:38 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Mark
Thank you for your input. I do always charge with balance lead attached. Charger has charge and balance charge mode.
Discussion Charging TX LiPo Battery Beg. Question AeroWRX Batteries and Chargers 3 Apr 09, 2012 08:36 AM
Discussion LiPo Charge/Storage question Zenmaniac Batteries and Chargers 7 Mar 17, 2012 10:24 PM
Discussion Recommended Charge Rates LiPO rowekmr Batteries and Chargers 3 Feb 15, 2012 02:19 PM
Discussion 11.1v lipo battery charge rates? Marty7n Batteries and Chargers 2 Oct 12, 2011 01:33 PM
