Old Nov 14, 2013, 07:41 PM
Little Red Plane
United States, TN, Knoxville
Joined Dec 2012
Question
Looking for some decent wing servo reccomendations
When they were on sale I purchased four Spektrum A7010 wing servos for a project that I am working on.
What is the general opinion of these servos? Are they something that I'm going to regret putting in my wings?
I'm basically a club flyer that will compete in a few contests, so I don't feel the need for the most expensive servos, but then I don't want to use the most unreliable ones either.
What would you use in my situation?
As always,
Thanks in advance!
GarryOgilvie is online now Find More Posts by GarryOgilvie
Old Nov 15, 2013, 01:56 AM
Romania, Dolj, Craiova
Joined Sep 2007
They still are, on Amazon, for $19.
This price volatility, from $40 when not discontinued, to $7 the dealers price, and $12 how I bought them myself, make me think once again to the relativity of "you get what you pay" and "cheap chinese stuff"
renatoa is offline Find More Posts by renatoa
Old Nov 15, 2013, 05:22 PM
banjo328's Avatar
Albuquerque, NM
Joined Jan 2010
I like these, use them for flaps and ailerons on my f5J planes and on the spoilers on my RES Mystique. The torque isn't as great as a Futaba 3114 or Dymond D47, but the metal gears are more robust and the price is right, about $7 from HK, if I remember...
Blue Arrow D05010MG Digital 0.20 oz
(5.8 g) 0.770.341.06 in
(19.68.626.9 mm)
4.8V:
5.8 oz-in (0.4 kg-cm)
6.0V:
7.1 oz-in (0.5 kg-cm)
4.8V:
0.10 sec/60
6.0V:
0.09 sec/60
Coreless ? (add) Metal ? (add)
banjo328 is online now Find More Posts by banjo328
Old Nov 15, 2013, 06:24 PM
Little Red Plane
Joined Dec 2012
Thanks for the recommendations so far,
I'm looking for something that is good for a 3-4 meter span that won't break the bank!
And what are the opinions of the A7010 Spektrums?
Old Nov 15, 2013, 07:11 PM
the anthropocebo effect
kcaldwel's Avatar
Joined Jan 2007
I've been using some of the 115 and 135 KST servos. They seem quite good: fast, good centring and holding power. Servormances' testing shows not quite as good performance as KSTs, but for $24 they seem very good. The 135s are a bit smaller and lighter, but Servormances recommends using the 125s if you have space:
http://www.alofthobbies.com/kst-ds125-wing-servo.html
http://www.aeroglide.net/2013/02/ser...-fevrier-2013/
KST also has an 8mm thick 12g servo that HyperFlight is carrying.
Servormances hasn't tested any Spektrum servos, and my only experience with the brand was some little digitals that were truly awful.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 22, 2013, 08:28 AM
landings=takeoffs=good
Battman540's Avatar
Harvest, AL
I do not recommend the Spektrum 7010 servos! I've had three of them fail so far. The electronics is the problem. The 7020 is no better.
If you want a good thin wing servo try these. They work well.
http://www.hobbyking.com/hobbyking/s..._23g_USA_.html
If you are on a tight budget, these will work but aren't as good at the Turnigy.
http://www.hobbyking.com/hobbyking/s...?strSearch=d-m
I own and fly both of these servos and they work well. Good luck!
Battman540 is offline Find More Posts by Battman540
Old Nov 22, 2013, 05:43 PM
USA, CA, Chico
Joined Feb 2011
Those ALL look like good choices at good price. So would the HK or KSTs be better in your guys opinion ??
Airman74 is online now Find More Posts by Airman74
Old Nov 23, 2013, 06:35 AM
Joined Sep 2007
From HK, the Blue Bird/BMS servos are my favorite, at decent price for a quality exceeding Hitec in many cases.
Replaced a HS 80 in a very demanding place, tricopter yaw servo, where two units broken one after the other in less than one month, with a BMS 380 that still work today.
Since then half of my servos in various 2m+ gliders are BMS.
Found about them reading a Trappy quote about the 380Max MG, as better than anything has Hitec in this class.
Wanted Looking for some HS-65MG servo arms joker24458 Aircraft - General - Radio Equipment (FS/W) 0 Sep 21, 2013 02:00 PM
Wanted Looking for a Fixed Wing with 30 min flight times or more I have some RC to trade koss1000 FPV Equipment (FS/W) 0 Jul 28, 2013 01:49 PM
Discussion Looking for a decent F-16 90mm Foamie bonefishfool Foamy EDFs 2 Jul 07, 2013 06:25 PM
Wanted Looking for some nice servos to put in my neos. XavierG Aircraft - Sailplanes (FS/W) 0 Jun 17, 2013 11:25 AM
Discussion Looking for a decent servo under 4g AMTJIM Radios 6 Feb 10, 2009 08:05 AM
