Old Oct 31, 2011, 07:45 PM
I have no friends
mt_100's Avatar
United States, MI, Holland
Joined Dec 1996
Futaba 10C with Spektrum Voltage Dance
Does anyone out there have a 10C with Spektrum module in it and notice the voltage "dances"?
Mine will show a voltage and then very quickly change back and forth to .1v up or down from there, very fast.
However, if I hold the range check button on the module it stays solid.
Anyone else notice this?
mt_100 is online now Find More Posts by mt_100
Old Oct 31, 2011, 07:59 PM
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
My 9C does it too and it is normal. It is the way the Spektrum module draws power in normal mode. In range check mode the output power is reduced and as a result the current draw also decreases so the battery voltage stays constant.
ivanc is offline Find More Posts by ivanc
Old Oct 31, 2011, 08:56 PM
I have no friends
mt_100's Avatar
Joined Dec 1996
Good to know, thank you.
Old Nov 01, 2011, 06:51 AM
United States, FL, Miami
Joined Aug 2009
If you want to get rid of the voltage dance on your DM8 module, all you need to do is hook up a capacitor to the positive and negative pins of the module (I believe pin 2 = positive and 4 = negative) How small of a cap ? I dont know. I used an exaggeration of a capacitor (1000uf) to initially test it out and will do a cleaner job whenever I get the time for that.
I believe Andy Kunz stated that the module cycles on and off many times a second which is what freaks the Futaba voltimeter out.
And yes, a caveman could have done a better looking job.
pach is offline Find More Posts by pach
Wanted Spektrum DX8 and Rxs For Sale/Trade - Futaba 10C w/Synth Modules look! banzi28 Aircraft - General - Radio Equipment (FS/W) 3 Oct 06, 2011 10:08 AM
Found Spektrum Module DM8 for futaba 9c/10c radio jfint Aircraft - General - Radio Equipment (FS/W) 4 Mar 08, 2011 10:33 PM
Discussion can't get E-flite Blade MX s300 to work with spektrum module on Futaba 10C Capy-Norway Micro Helis 1 Jun 26, 2009 09:32 AM
Discussion Futaba 10C Spektrum or DX7 with a twist? djbentle Radios 11 Feb 03, 2009 06:47 PM
Question Futaba 10C with Spektrum module? village_idiot Radios 3 Oct 01, 2008 11:52 AM
