Old May 14, 2016, 03:47 AM
mdelaney14 is offline
Find More Posts by mdelaney14
Joined Mar 2016
Question
Control as3x from spektrum transmitter
Am I going nuts or did I see a menu item for controlling as3x gains after I did a firmware upgrade on my DX9? I can't find any documentation anywhere on this.
mdelaney14 is offline Find More Posts by mdelaney14
Old May 14, 2016, 05:14 AM
BoxCar31 is online now
Find More Posts by BoxCar31
Perpetual Noob
BoxCar31's Avatar
United States, NC, Arden
Joined May 2015
Did you look in the Change Log?
Version 1.06
Changes since 2014-April-18
New Features & Improvements
• Added AS3X Gain monitor functions for use with AR636, AR6335, and similar
AS3X receivers. When you enable telemetry option AS3X, you are able to see
gain status in real time, and adjust it with a trimmer. Note that this function
performs the following re-configurations in your radio:
o The F-Mode switch has its outputs set to the proper values for AS3X
operation. If you are using it for other purposes, you will need to
reconfigure those features to allow AS3X to use them.
o Mix 16 (DX10t and higher) is used to control AS3X gain.
o The selected channel is reconfigured for proper control. If you change the
channel, you will need to manually re-assign the old channel to its desired
purpose.
o Enables a screen “AS3X Gains” on the Function List to configure
parameters.
o Enables the AS3X telemetry gain monitor on the telemetry screens.
o If you are using a DX6, you can tweak the gains using the roller while on
the AS3X Gains configuration screen. If you are using a higher radio, you
can adjust at any time using the desired trimmer.
BoxCar31 is online now Find More Posts by BoxCar31
Old May 15, 2016, 10:10 PM
Joined Mar 2016
Thanks for the post. It was very informing. I am guessing that the "change log" is found on the spektrum website. There are several people in my flying club staying away from AS3X because it seems difficult to find information on the set up. I know there is a lot on utube, but there is little information packed in the the BNF foamie model box. Thanks again!
Old May 15, 2016, 11:03 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
It's one of the two links under the big orange DOWNLOAD button on the update page. Download both PDFs.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old May 16, 2016, 12:21 AM
Joined Mar 2016
Thanks Andy,
One of the reasons I am trying to learn as much as I can about AS3X is I think I see real advantages to it since it always seems windy at our club site, but a lot of people are staying away from the receiver because they aren't aware of the important transmitter set up specs. I think the utube videos are great, but not everyone watches them. When I bought my Rare Bear, I knew nothing about what should be adjusted only in the receiver. I promised to help some of the more courious tech savy guys with this. Thanks for the post!
Discussion Transmitter to Flight Controller Latency - SBUS vs Spektrum Satellite MitchMan Radios 5 Feb 16, 2016 02:37 AM
Help! Can't control pitch from transmitter SirRexAlot Aerial Photography 4 Jan 17, 2016 06:56 AM
Discussion FPVfreerider: transitioning from ps3 controller to real transmitter greenlight149 Multirotor Beginner 5 Nov 28, 2015 01:44 PM
Sold Spektrum ar636a receiver with as3x from ArtiZan 1987tc Aircraft - General - Radio Equipment (FS/W) 5 Oct 05, 2015 01:32 AM
