Old Jan 13, 2016, 07:52 AM
arnauddecotter is offline
Find More Posts by arnauddecotter
Australia, WA, Perth
Joined May 2014
spinner on pusher props?
Hi.. i have been aaking uncle google do we need a spinner"nose cone" on a pusher prop.
Cant find any info.
does anybody knows if a spinner"nose cone" makes a difference on a pusher prop setup.
btw. Check my fpv viper pusher prop thread
arnauddecotter is offline Find More Posts by arnauddecotter
Old Jan 14, 2016, 06:49 AM
Granted is offline
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
You do not, it makes no difference.
Granted is offline Find More Posts by Granted
Old Jan 14, 2016, 01:45 PM
MRGTX is offline
Find More Posts by MRGTX
MRGTX's Avatar
United States, CT
Joined Aug 2005
I agree that you don't need one but I'm not convinced that it makes "no difference."
Every full scale pusher in the world seems to use them.
Personally, I think they look cool, possibly help a little with aerodynamics...and in some rare cases, it might help when trying to balance a plane with a bigger than normal battery up in the nose.
MRGTX is offline Find More Posts by MRGTX
Old Mar 24, 2016, 12:58 AM
Joined May 2014
I wonder if as an aerodynamic effect on the flow of air created by the prop.. like a more linear flow behind the plane
Old Mar 24, 2016, 05:55 AM
Quorneng is offline
Find More Posts by Quorneng
Joined Feb 2007
The problem with a pusher spinner is really its shape.
A leading edge can be a fairly bluff rounded shape without incurring a significant drag penalty, however a trailing edge has to have a long shallow taper to be aerodynamically efficient.
The question really is whether a pusher spinner makes a significant difference rather than it has no effect.
Have a look at images of a civil Cessna Skymaster. Its rear spinner is quite long and pointed (In fact they use the same at the front as well) but compare it shape to say a Spitfire or Mustang spinner which although much faster plane has a more rounded profile.
Quorneng is offline Find More Posts by Quorneng
Question How to set the "down thrust" on a pusher prop aircraft ? Dreamcatcher Foamies (Scratchbuilt) 13 Nov 04, 2015 03:03 AM
Question Can I reverse two wires on a brushless motor and make it a pusher using a pusher prop hog2soar Power Systems 6 Sep 08, 2015 01:12 PM
Discussion twin motor prop rotation on pusher plane karfrik Power Systems 7 Feb 19, 2015 06:13 PM
Discussion standard prop rotation on pusher twin ejohn Power Systems 3 Jul 07, 2014 08:52 AM
Sold Spinner, APC Props, Pusher Props too Paranoia Aircraft - Electric - Power Systems (FS/W) 8 Nov 19, 2006 11:08 AM
