Old Jan 07, 2016, 09:04 PM
ChuckTseeker is offline
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
E-Flite Carbon-Z® P2 Prometheus BNF and PNP
Looks like someone opened the bag too soon as i saw this come up this morning but then all links to it disappeared
looks nice if it happens!
Put this code in from the photo to a fresh page http://bit.ly/1PdKC9H which mentions nothing about this plane and this was what the link lead to on the HH site
Sorry, your search for "efl_prometheus" did not return any results. Please try another search
http://www.horizonhobby.com/SearchDi...ce=Q&pageView=
cheers chuck
A little more info i found
7 hours. Let's go with our fireworks at news! grin emoticon like emoticon
In Skip Stewart's spectacular high-Alpha Messerflug on the airfield - with the e-Flite Carbon-Z P2 Prometheus. You've always wanted to fly like skip Stewart? No problem. After the p3 we get also the p2 prometheus in the hangar of our skip Stewart Airshow models. By The Carbon-Z-technology is the p2 so hard and stiff like a wooden model. Through the significantly lower weight, however, much more powerful. The E-Flite Carbon-Z P2 Prometheus - at least as impressive as the original.
Psst... Hold on. In an hour, there's the next model. wink emoticon
‪#‎Horizon‬ Hobby ‪#‎Eflite‬ ‪#‎Skip‬ Stewart Airshow ‪#‎p2p‬ Rome theus
all the info at last haha
Key Features
Easy to complete final assembly
Skip Stewart Airshows officially licensed adaptation
Highly-tuned airframe for extreme aerobatics by Mike McConville
Rigid Carbon-Z® construction delivers a strong yet lightweight airframe
AS3X® technology enhances precision for a rock-solid feel
Powerful 50-size brushless motor
High-voltage 70A brushless speed control
Spektrum™ 6-channel AR636A DSMX® receiver
Durable Spektrum metal-gear mini servos
Accepts a 4400mAh 6S 22.2V Li-Po battery (sold separately)
High-strength aluminum landing gear with matching finish
Large control surfaces with double-beveled hinge lines
Tool-free I-strut installation for fast field assembly
Overview
From his performance of the world’s smallest loop to being the only air show pilot to combine aerobatics with motocross by flying his P2 Prometheus under a jumping motorcycle, Skip Stewart brings dare-devil creativity to precision aerobatics. Coined “High-Octane Aerobatics,” Skip’s performances offer an appetizing menu of stunts that blanket the horizon with mind-blowing agility at an energy level that packs airshows around the globe with cheering fans.
The E-flite® Carbon-Z® P2 Prometheus aircraft is for aerobatic pilots who want precision in an unlimited biplane with unique character. Based on the custom built P2 Prometheus airplane flown by Skip Stewart, Mike McConville adapted the unique design as a model with performance that’s as inspirational as Skip’s original. Exclusive Carbon-Z technology allows a healthy sized model such as this to be rigid like a conventional all-wood airframe, yet lightweight so it can have a larger performance envelope than any other biplane in its class. Durable Z-Foam™ material used in construction means that any bumps along the way are simple to repair. The Carbon-Z P2 Prometheus looks the part too with flame-laden graphics and control surfaces large enough to handle bold moves such as the Skip’s signature high-alpha knife edge passes. Engineered to fly great from the start, the Bind-N-Fly® version of this hot rod features built-in and expertly tuned AS3X® technology which makes flying an extreme aerobatic thriller such as this even more satisfying.
The Famous P2 Prometheus
Air show performances by Skip Stewart in his P2 Prometheus are enjoyed by aviation fans around the globe. The Carbon-Z® P2 Prometheus biplane is capable of performing Skip’s signature moves with power spare and the kind of control authority that’s a pilot’s dream.
AS3X® Technology
The BNF Basic version of the Carbon-Z P2 Prometheus biplane features the advanced AS3X® (Artificial Stabilization – 3-aXis) system. Built into the Spektrum™ 6-channel AR636A receiver, AS3X technology is what helps give this extreme aerobatic hot rod an incredibly solid feel in the air. It works behind the scenes to help counter the effects of wind and turbulence by combining multi-axis sensing with specially tuned flight control software. As a result, the P2 Prometheus is a more enjoyable experience because your workload to fly smoothly is significantly reduced.
Mike McConville Design
World-class aerobatic pilot, Mike McConville, worked closely with the full-size P2 design and adapted the unique biplane flown by Skip Stewart to deliver the perfect balance of performance, optimal power and strength.
Carbon-Z® Technology
Exclusive Carbon-Z technology features composite construction that allows major components like the wing to be chambered, significantly reducing weight while increasing rigidity to comparable all-wood construction.
Expertly Tuned
The installed Spektrum™ 6-channel DSMX® receiver of the BNF Basic P2 Prometheus version features AS3X® technology that’s been programmed to give the feeling of expertly tuned flight, right out of the box.
Brushless Power
Under the sleek cowl is a powerful 50-size brushless power system that features a high-torque 525Kv motor, a 70-amp brushless ESC and 15x5.5 propeller for the authority to hover and accelerate vertically.
High-Voltage System
With the 4400mAh 6S 22.2V Li-Po battery you provide, expect extreme performance for high-alpha knife edge flight, vicious tumbles, Harrier moves and hover-power that provides unlimited vertical.
Easy Assembly
Each plug-in wing features carbon-fiber wing tube support that secures with a single screw. The aileron linkages simply snap into place and concealed through-pins quickly connect the I-struts into molded pockets.
Product Specifications
Wingspan: 48.0 in (1219mm)
Overall Length: 49.3 in (1252mm)
Wing Area: 840 sq. in. (54.2 sq. dm)
Flying Weight: 7.0 lb (3.2 kg)
Motor Size: BL50, 525Kv brushless outrunner
Servos: (4) 25-gram mini metal-gear servos
Prop Size: 15 x 5.5, 2-blade
Speed Control : 70-amp brushless ESC
Recommended Battery: 4400mAh 6S 22.2V 30C
Approx. Flying Duration: 4 to 5 minutes (approx.)
Scale: 20%-Scale
Experience Level: Advanced
Recommended Environment: Outdoor
Assembly Time: Less than 1 Hour
https://youtu.be/gm-713CN2AE
ChuckTseeker is offline Find More Posts by ChuckTseeker
Old Jan 08, 2016, 03:36 AM
hinzer is offline
Find More Posts by hinzer
Canada, BC, Abbotsford
Joined Sep 2011
nice!
hinzer is offline Find More Posts by hinzer
Old Jan 08, 2016, 04:28 AM
slopetrashuk is offline
Find More Posts by slopetrashuk
You must die! I alone am best.
slopetrashuk's Avatar
The Naughty Corner..Find me tweeting @slopetrashuk
Joined Sep 2003
Yeh, that disappeared pretty damn quickly after my son watched the video and came to the workshop shouting Dad, Dad Daaad!!!
slopetrashuk is offline Find More Posts by slopetrashuk
Old Jan 08, 2016, 08:00 AM
Dave Eichstedt is online now
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
It's real, and live now. Video link doesn't seem to work.
Dave Eichstedt is online now Find More Posts by Dave Eichstedt
Old Jan 08, 2016, 08:31 AM
DarkGriffin is offline
Find More Posts by DarkGriffin
United States, MA, Haverhill
Joined Dec 2015
Pre-Ordered. Can't wait! Was just thinking last week as I was flying the P3 it would be great to have a 1.2m or larger plane of this. My dreams came true.
DarkGriffin is offline Find More Posts by DarkGriffin
Old Jan 08, 2016, 08:33 AM
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
Video is working now.
E-Flite Carbon-Z® P2 Prometheus BNF and PNP (3 min 0 sec)
Old Jan 08, 2016, 09:02 AM
Joined Dec 2015
Much better info on the plane.
http://www.e-fliterc.com/Products/De...#quickFeatures
Old Jan 08, 2016, 09:21 AM
wgarman is offline
Find More Posts by wgarman
More Planes Than Sense
wgarman's Avatar
United States, PA, Wexford
Joined Feb 2010
Think it will handle the 5000mah batteries from the Carbon-Z T-28?
wgarman is offline Find More Posts by wgarman
Old Jan 08, 2016, 10:04 AM
Fentonflyers is offline
Find More Posts by Fentonflyers
United States, MO, Fenton
Joined Jan 2012
Maybe but lighter is always better with 3d. If you plan on sport flying I would think it would be fine as long as it fits.
Fentonflyers is offline Find More Posts by Fentonflyers
Old Jan 08, 2016, 11:14 AM
edge_pilot is offline
Find More Posts by edge_pilot
From a Different Planet!
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
Damn, Horizon! I said no more planes for this year, this just broke my New Years resolution. That lasted a week. LOL
edge_pilot is offline Find More Posts by edge_pilot
Old Jan 08, 2016, 11:41 AM
stitch1 is offline
Find More Posts by stitch1
Stitching 'em back together!
stitch1's Avatar
United States, MO, Lee's Summit
Joined Jun 2012
Subscribed.... I think I need one of these in my life.
stitch1 is offline Find More Posts by stitch1
Old Jan 08, 2016, 12:43 PM
Cyclone Steve is online now
Find More Posts by Cyclone Steve
My head in the clouds!
Cyclone Steve's Avatar
United States, CO, Colorado Springs
Joined Mar 2014
Just take my money!
Cyclone Steve is online now Find More Posts by Cyclone Steve
Old Jan 08, 2016, 03:25 PM
echoplanar is online now
Find More Posts by echoplanar
echoplanar's Avatar
Lafayette, CA
Joined Aug 2002
This one looks too good to pass up.
echoplanar is online now Find More Posts by echoplanar
Old Jan 08, 2016, 04:09 PM
SLYDoggie is offline
Find More Posts by SLYDoggie
United States, TN, Nashville
Joined Nov 2012
Here is a video that is currently working. All the others I have seen, including the one on the HorizonHobby web site show as "Private".
SLYDoggie is offline Find More Posts by SLYDoggie
Old Jan 08, 2016, 05:24 PM
Joined Mar 2014
Hmm. I've watched the one on Horizon's website over and over again!
I've gotta sell some planes and make some room. I must have this plane.
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 4129 Jul 01, 2016 12:17 AM
Sold E-flite Carbon-Z T-28 (78") Wingspan - PNP ebelling1 Aircraft - Electric - Airplanes (FS/W) 8 Oct 13, 2015 06:30 PM
Sold E-flite Carbon-Z T-28 (78") Wingspan - PNP ebelling1 Aircraft - Electric - Airplanes (FS/W) 4 Sep 28, 2015 08:51 AM
Sold E-flite Carbon-Z Splendor PNP $130 LPU South Houston/Clear Lake richman03 Aircraft - Electric - Airplanes (FS/W) 2 Aug 19, 2015 07:38 AM
Sold E-Flite Carbon Z Yak 54 PNP donpzal Aircraft - Electric - Airplanes (FS/W) 7 Dec 29, 2013 06:06 AM
