Old Nov 28, 2015, 10:06 AM
daved20319 is offline
Find More Posts by daved20319
United States, WA, Twisp
Joined Sep 2013
Question
Control throws?
Are there any settings in Phoenix that would have the same effect as physically increasing or decreasing control throws? Or is that purely radio programming?
And on a related subject, when selecting certain models, a list of settings pop up in the lower right hand corner of the screen. How do I alter those settings, or is this also a case of radio programming?
One last question I've asked before but didn't get an answer to, do the motor choices in the model edit screen actually do anything, or are they just different sound files? Thanks.
Dave
daved20319 is offline Find More Posts by daved20319
Old Nov 28, 2015, 10:39 AM
yorkiepap is offline
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey Dave,
You can go to the "SYSTEM" list on the toolbar, go down to "Your Controls", & when the "Your Controls" box appears, click on "Edit Profile", & then click on "Detailed". You will see on the left & right sides are "0" & "100" that will set your travel movements. Remember, this will affect ALL the models you select in the program. I have my JR10X setup for both Phoenix & RF7.5 under the Model Selection on my radio since both programs have separate command parameters. Then with each program, I found it easiest to simply input Dual Rates & Expo on 1 switch for simplicity. I have Pos 0=100/100; Pos1=80/15; Pos2=65/25 that seems to work quite well for all the models.
Be sure to go thru the Calibrate function & make a "New Profile" for your radio make/model that you are using under the "Your Controls" window. You can simply use any radio with a separate profile listing in this window.
Denny
yorkiepap is offline Find More Posts by yorkiepap
Question Control throw distances for a Hobby King Flybeam RonK99 Electric Plane Talk 7 Aug 30, 2015 02:42 PM
Discussion Measuring Control Throw Angle darticus 3D Foamies 8 Jul 27, 2015 10:28 AM
Discussion How to estimate best control throws? mgdon Beginner Training Area (Aircraft-Electric) 6 Jun 26, 2015 08:38 AM
Discussion Servo throw vs control horn throw ottootts F3A Pattern 11 Sep 04, 2012 08:26 PM
