Old Jul 02, 2012, 12:10 PM
anotherdebt is offline
Find More Posts by anotherdebt
anotherdebt's Avatar
United States, NC, Mooresville
Joined Feb 2012
Motor or ESC
Hey all I need help trouble shooting my electronics. Basically I have a quad that is having issues maintaining throttle. By this I mean that when throttled up the quad takes off like it should, climbed to where ever I decide to settle in within reason. No more than about ten feet and all of a sudden it's like the ESC starts to shut down the power and the quad settles to the ground no matter how much throttle I give it. If I let It sit a minute and than throttle it up again it lifts off but than quickly looses power again. No with that being said I do have a motor with a slightly bent shaft and this motor gets exceptionally hot to the point of smoking. So I am pretty sure the motor is bad but will that cause a power loss for the rest of the motors? I am in the process of ordering new parts I just want to make sure that I buy enough. It seems to me like maybe a ESC is faulty but I am not sure how to tell. The other thing is that none of this seems to an issue without props in place, but I kind of expect with no load this would be the case.
Clinton
anotherdebt is offline Find More Posts by anotherdebt
Old Jul 02, 2012, 09:28 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Clinton
Try to test the suspected bad ESC with one of your good motors on the ground. (I don't fly quads, so you have to figure out how to do that).
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jul 02, 2012, 11:15 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
"the ESC starts to shut down the power and the quad settles to the ground no matter how much throttle I give it. If I let It sit a minute and than throttle it up again it lifts off but than quickly looses power again."
Clinton;
From your description, your ESC and motors are doing their jobs.
I think your battery is too small, defective. The ESC is signalling low voltage.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jul 03, 2012, 11:50 AM
Joined Feb 2012
Well when i use those same batteries both 2s and 3s for my helies they are fine also the charger is showing the batteries almost full. That was my first thought when it began.
Old Jul 03, 2012, 12:11 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
I agree, sounds like a sad battery. Try a bigger one, or one with a higher c rating. Running four esc's off one battery must be pretty demanding.
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Help! Electronics got wet. ESC or motor broken? Daniel S Waterplanes 10 Aug 03, 2012 03:35 AM
Discussion magic smoke: ESC killed motor, or motor ESC ? mopetista Power Systems 4 Mar 13, 2012 03:50 AM
Sold 45 or 50A ESC w/Bec will trade Hacker 2026M motor or Pheonix 25A ESC Flyextreme Aircraft - Electric - Power Systems (FS/W) 2 Nov 21, 2007 10:52 PM
Sold Rimfire motor, and Electrifly 9A ESC. $50 for both, or $30 for motor, and $20 for ESC edge5foamy Aircraft - Electric - Power Systems (FS/W) 4 May 18, 2007 12:18 PM
Wanted BP-21 or similar motor or motor/esc combo pc_pilot Aircraft - Electric - Power Systems (FS/W) 2 Jul 27, 2006 12:21 AM
