Old Nov 09, 2008, 09:17 PM
I make bad look so good.
SteveC68's Avatar
League City, Texas
Joined Sep 2006
EDF55 shaft size?
Will a motor with a 2.3mm shaft work with the EDF55 or does it have to have a 2mm shaft motor?
Steve
SteveC68 is offline Find More Posts by SteveC68
Old Nov 09, 2008, 09:42 PM
shschon's Avatar
United States, CA, SF
Joined Aug 2004
Steve
As far as I know GWS only makes 2mm adapter and recently some 3 mm adapter for their EDF55/64.
You might want to either turn down your motor shaft diameter or look for after market parts.
shschon is offline Find More Posts by shschon
Old Nov 11, 2008, 04:15 AM
Taipei, Taiwan
Joined Oct 2005
Hi Steve,
Shschon is correct, the old version shaft adapter on EDF55/64 was 2mm one as the motors used were all with 2mm shaft, while the current version shaft adapter is in 3mm as the brushless motors used on them are with shaft in 3mm, ie GWBLM005AZ or GWBLM005Z.
Chen
GWS CHEN is online now Find More Posts by GWS CHEN
Old Nov 13, 2008, 08:33 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Chen
What is the part# for the 3mm shaft adapter and does anyone in the USA have this part in stock?
Sammy70 is online now Find More Posts by Sammy70
Old Nov 14, 2008, 04:21 AM
Taipei, Taiwan
Joined Oct 2005
Hi Sammy,
The part number of 3mm adapter for EDF55&64 is GWADP003C. Just check out this link for all EDF parts, http://www.gwsus.com/english/product.../edf_parts.htm Would you visit www.caliberhobby.com if you could not find it out locally.
Chen
Astro Flight 05 shaft size? slapshot460 Electric Plane Talk 3 Sep 30, 2002 01:56 PM
Mega Motor Shaft Size?? Paul Susbauer Sport Planes 2 Mar 26, 2002 01:22 PM
Endoplasma shaft size? Bill Glover Sport Planes 14 Dec 20, 2001 10:23 AM
GWS IPS motor shaft size frankenfoamy Electric Plane Talk 2 Jul 27, 2001 09:33 AM
x-250 shaft size? temacc Electric Plane Talk 10 May 01, 2001 04:23 AM
