Old Mar 10, 2002, 07:33 PM
concord Ca
Joined Jan 2002
How do I time my speed 400 motor?
How do I time my speed 400 motor? A friend of mine saw the sparks coming off my speed 400 motor brushes. He said that there is supposed to be a way to time the motor so the motor stops sparking. Thanks Roy
rockdean is offline Find More Posts by rockdean
Old Mar 10, 2002, 07:50 PM
louisiana
Joined Nov 2001
timing tool
hobby lobby has a timing tool for the speed 400
zagiking is offline Find More Posts by zagiking
Old Mar 11, 2002, 09:27 AM
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
rock:
Do a search and also got to the faq section here in ezone.
poobs is offline Find More Posts by poobs
Old Mar 11, 2002, 05:24 PM
concord Ca
Joined Jan 2002
Thanks for the help. Rockdean
Old Mar 11, 2002, 05:37 PM
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
rock:
I was at work when I repplied to your post. Sorry if I was "short".
If you need help beyond what the FAQ covers plese let us know.
One thing not covered is that you can move the back plate with a very sharp needle nose. I made a timing tool by grinding an old pair of needle nose pliers.
Good luck
Old Mar 11, 2002, 08:41 PM
concord Ca
Joined Jan 2002
Sorry
I didn't think that you were short. I found the timing tool on line, but what do I do with it? Do I need a timing light or something?
Old Mar 12, 2002, 03:15 AM
gerard_nl's Avatar
eindhoven / the netherlands
Joined Mar 2002
poobs> could you explain how to time the speed 400?
i got loads of needle nose pliers ready to be ruined for a good cause.
also have 2 new permax speed 400 awaiting their destiny.
many thanks
gerard
gerard_nl is offline Find More Posts by gerard_nl
Old Mar 12, 2002, 06:26 AM
small electrics r BIG FUN
Iowa
Joined Aug 2000
I received a new motor that sparked like crazy and had no power. Timing marks were in the neutral (normal) position. Never did check out what was wrong with it. So timing may or may not be the problem.
This link has some useful information :
http://rcflier.rcplanet.com/RC_Info/...g%20proceedure
And spend the price of a few beers or whatever on the proper tool. It makes the job SO easy and much safer than sharpened pliers.
Al P is offline Find More Posts by Al P
Old Mar 12, 2002, 09:14 AM
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
The procedure found in the site that Al P has posted sounds very good.
Discussion how do you retime a brushed 400 motor? Bobnormal Electric Motor Design and Construction 5 May 02, 2006 12:52 PM
How short do I cut my speed 400 shaft? ferradas Electric Plane Talk 5 Feb 21, 2002 05:31 PM
How many turns on a speed 400 motor stealthy Power Systems 5 Dec 14, 2001 11:34 PM
How do I test my speed controller? repo32 Electric Plane Talk 1 Sep 25, 2001 07:02 AM
Should I break in my speed 400 motor? funflyer Power Systems 3 Jun 14, 2001 03:17 AM
