Old Dec 04, 2012, 05:24 PM
Joined Nov 2012
Engine recomdations
Hi all,
I'd like some advice on what kind of steam engine would be suitable for my ore boat. She's 12' long 1' depth 28" beam weight up to 600lbs loaded. Prop is 4 bladed and I would like her to move at 12 scale knots. I can push her alonge with my finger with little pressure.
you can see pictures on the scale boat forums on this site under "12' lake freighter 1/24 scale ".
Any thoughts on putting 2 TVR1A 's together?
Thank you Eric
Eric Klein is offline Find More Posts by Eric Klein
Old Dec 04, 2012, 06:55 PM
steveciambrone's Avatar
United States, CA, Santa Clarita
Joined Dec 2005
What diameter propeller can you fit on her?
Steve
steveciambrone is offline Find More Posts by steveciambrone
Old Dec 04, 2012, 07:44 PM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Eric's freighter thread:
http://www.rcgroups.com/forums/showt...ter+1+24+scale
Eric says in his other thread:" I'd really love steam." In that case, you should follow your heart. Some thoughts:
1. w/o model steamboat experience your first setup will probably not be your last. Make everything easily removable so you can change things easily. Use silicon model airplane tubing for steam lines (instead of bending metal lines). Your first goal is to get something that moves the boat, your 2nd goal will be to get it to move the way you envisioned.
2. One steam motor will move the hull. More motors will give you faster acceleration, and possibly excess power to allow you to deal better with wind. I'd start simple. TVR1A is a good motor, fairly inexpensive, easy to construct. You will be playing with prop size and pitch to get it to work well. Learn to bend some simple props out of sheet steel (tin can lids?). Probably no one (still alive) has done what you are doing, so you are the experimenter.
3. Don't add steam accessories until you have a setup that moves the boat. Accessories such as water pumps, large steam oil tanks, big fuel tanks, boiler water makeup tanks, etc. can be added later. Unless you have a will of iron, the patience of a saint, and lots of spare time, debugging accessories may lead to burnout before you ever get to see her move on the water. Dream big, but start small, planning on making incremental improvements that build on prior success. There are a plethora of variables in steam ops. Which means, when it doesn't work, figuring out the solution can be very frustrating....so minimize the initial variables as much as possible. I find that steam power is fascinating, more so than electric power. But there will be a learning curve :-).
Hope this helps.
Brooks is offline Find More Posts by Brooks
Old Dec 04, 2012, 10:21 PM
Joined Dec 2005
I would start with the Stuart D10 or Saito T2GR, engines, both have a bore and stroke around 3/4 x 3/4'" The Stuart will turn a very large propeller I would start at 4" and it might handle a 5" propeller. The large MAC boiler would be a good match to both engines. You are looking at a expensive investment but you have a very large model.
thanks
Steve
Old Dec 10, 2012, 06:51 PM
Joined Nov 2012
Thanks for the advice expecialy on keeping it simple, I do have the pretenceity to make things overly complicated.
She has a 5.5" 4 bladed prop.
Eric
Old Dec 18, 2012, 08:05 PM
we2
Joined Sep 2011
I have just received the Dumas Creole Queen build kit and would like to steam power it. Has anyone else done this with this kit? What is the best engine/engine kit? How about prop and size? I would like to get this planning underway so that I can do what ever mods are required to adapt the steam engine as the kit build progresses.
we2 is offline Find More Posts by we2
Old Dec 18, 2012, 08:14 PM
we2
Joined Sep 2011
correction
Boat is a paddle wheeler! No prop!
For Sale More are already Here...THE ENGINES ARE COMING! THE ENGINES ARE COMING! wifeswarrior Aircraft - Fuel - Engines and Accessories (FS/W) 8 Jul 28, 2012 11:01 AM
Sold Sig SH-626 engine mount for .60 to .91 engines plus other mounts jsesere Aircraft - Fuel - Airplanes (FS/W) 1 Apr 29, 2012 10:02 AM
Sold NEW Gas Engine the same size as a .91-1.20 Glow Engine!!! unclegeorge Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 08, 2012 11:34 AM
Sold 2x nib trainer planes with or w/o engines. engines are slightly used crash8384 Aircraft - Fuel - Airplanes (FS/W) 3 Mar 30, 2012 04:46 PM
Discussion Next plane recomdations. chaos2984 Beginner Training Area (Aircraft-Electric) 19 May 22, 2011 02:51 AM
