Old Aug 29, 2010, 10:52 AM
IFHELI's Avatar
United States, RI, Woonsocket
Joined Apr 2010
450 size 212/412 W/ Blade 400 installed
I have two of the wing wing 212`s. One with a Quad head. The Blade 400 fits if you cut down the wood base plate without useing drop down tail mod. The quad head is flying without e-stab. The two blader has a sk-360 installed. I had been testing some 385mm blades on the 2 blader. They gave a good scale length but too wide. They are a bit touchy on controls so decide to go with my rotor tech 350 blades. Here`s a few pictures of the modified base
IFHELI is offline Find More Posts by IFHELI
Old Aug 29, 2010, 10:58 AM
IFHELI's Avatar
Joined Apr 2010
Here`s a few pictures of complete helis
Old Aug 29, 2010, 11:17 AM
Lake Zurich, IL
Good to know B400 without drop down tail.
1) How is the CoG?
2) Any build photos?
3) What is the weight?
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Aug 29, 2010, 12:13 PM
IFHELI's Avatar
Joined Apr 2010
The red/yellow is 2lbs. 13 1/2 oz. w/ one-6s 1300mah battery. The CG is right under main shaft.
The Camo is 3lbs. 2 1/2 oz. w/ two 3s 2200mah battery (6s). This one is nose heavy for flying without e-stab.
I don`t have any build photos. I knew I should have taken some of the plywood before and after.
Old Aug 29, 2010, 01:25 PM
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Youre doing 6S, eh? Good stuff 385's...I take it these are bigger than the Heliartist version of the Bell heli. Nice work!
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Aug 29, 2010, 02:06 PM
IFHELI's Avatar
Joined Apr 2010
I have been doing 6S on 450 size helis for along time. I only have one not useing 6s and it is 4s in a Fusuno BO-105. The 385 blades were cool looking on it just too wide. If they were about 35mm instead of 45mm wide I may have kept them on the heli.
Old Aug 29, 2010, 02:55 PM
Redjestird Youser
Joined Jan 2009
Maybe 40mm wide would be a good compromise? Here's some pics of my UH-1M running some cut down 500 size blades...
http://www.rcgroups.com/forums/showp...&postcount=151
Definately gives a noticable improvement in lift, and flys really nice and scale-like with all that weight
Old Aug 30, 2010, 04:01 PM
IFHELI's Avatar
Joined Apr 2010
I saw that post. I need to adjust the settings in the SK-360 to see if I can calm it down some more. It is touchy on cyclics. It has a nice sound in the air at 1800-1900 HS. With the motor and gearing 1800 is my lowest HS possible useing GOV mod on ICE 50. I used my Gazaur Mar`s 480 belt on this one. It is a 515MXL instead of the 544mxl that came with fuselage. Here`s a pic to show tail clearance
Old Aug 30, 2010, 04:55 PM
Bad Creation's Avatar
United States, FL, Orlando
Joined Dec 2009
WOW very nice job i really dig those fuselage,s i will have to get me one of those
Bad Creation is offline Find More Posts by Bad Creation
Old Aug 30, 2010, 05:23 PM
Joined Dec 2009
IFHELI how do get to to that web site were you got those heli's from and were did you get the rised tail assembly thank you
Old Aug 30, 2010, 05:45 PM
IFHELI's Avatar
Joined Apr 2010
The raised tail comes with the fuselage. The belts that come w/ fuselages in my case were crap. I got the 212`s from www.hobbypartz.com. You can also get them @ www.xheli.com.
Old Aug 30, 2010, 05:57 PM
Redjestird Youser
Joined Jan 2009
Cool, and yeah, those 385's look kind of wide I'm not too sure how heavy yours is compared to the HA version, but with max weight reduction on mine (no lead on board and still balanced), I run it at 1650rpm. Now that sounds real nice . I need to try smaller tail blades from the 450pro blades as it makes a popping noise I assume from the tail rotor disk hitting the main tip vortexes, I have a 5.4:1 ratio on it, so lots of leeway. Hobbypartz has a nice selection of low-kv 450 motors to really quiet things down. I moved to a 1800kv (1700 actual) on 3S with 16T pinion on it...real quiet now. They are 22x20 stator size...so real close to Scorp level torque compared to the average ~16mm 450 motor, probably allowing bigger pinions with no ill effects.
Oh wait, youre running 6s...well, I guess 3S is a good place to 'downgrade' to also
Old Aug 30, 2010, 06:11 PM
IFHELI's Avatar
Joined Apr 2010
I get a bit of a pop noise also in the air but not all the time. After tweeking the Sk-360 some more,trying to lower HS is next on the list.
Old Aug 30, 2010, 08:38 PM
Joined Dec 2009
Thank you again IFHELI
Old Aug 30, 2010, 08:53 PM
My hobby is why Im broke
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
Hobbypartz and Xheli are one in the same.
Like Hobbyking and Unitedhobbies.com
I do wonder why some companies do this...
darthdrk is offline Find More Posts by darthdrk
Sold 2 EFLITE 1800mah batterys for a Blade 400/TREX 450 40.00 shipped decuzar Aircraft - Electric - Helis (FS/W) 0 Jul 25, 2010 11:44 AM
Sold Brand New PNP Blade 400 - Cheap 450 w/ Spares - BNF/ARF - You chose - Priced to Sell HeliFlyer711 Aircraft - Electric - Helis (FS/W) 5 Jul 11, 2010 03:16 PM
For Sale FS: New Blade 400 / Trex 450 LIPO Balanced Charger w/ AC Adapter $30 shipped watchguys Aircraft - Electric - Helis (FS/W) 0 May 18, 2010 12:47 PM
For Sale FS: New Blade 400 / Trex 450 LIPO Balanced Charger w/ AC Adapter $30 shipped watchguys Aircraft - Electric - Batteries & Chargers (FS/W) 4 May 12, 2010 09:18 PM
Question Bell 412 for 450 size heli darthdrk Mini Helis 5 Mar 23, 2009 06:49 AM
