Old Jun 10, 2014, 09:25 PM
Joined Jun 2014
Posted on wrong thread please disregard!
scruffy1972 is online now Find More Posts by scruffy1972
Old Jun 10, 2014, 11:01 PM
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Mikeruth
Thanks my Friend I was at work all day and I saw you responded...
I use the same method build fly adjust..
the CG of the superslo28 is honestly about the 4" mark back from the leading edge
but flying adjusting is the best method. also its a good way to correct other issues.
A plane that is well balanced and setup is so amazing to fly your going to be amazed at stuff you can do.
I also like doing flat spins with my plane and then using mixing to remove any dips and lift in level flight. then when you lay you plane in a knife edge she will track like she is on rails....
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: New GoPro Hero3+ Black Edition
Old Jun 11, 2014, 09:15 AM
Build, Launch, Crash, Repeat
United States, AZ, Litchfield Park
Joined Jan 2013
Thanks Mikeruth and tallflyer,
As always, this site comes through with all of the answers
Partyof5
Partyof5 is online now Find More Posts by Partyof5
Old Jun 16, 2014, 07:00 PM
Joined Oct 2013
Noob, need help with connecting esc to battery
When installing the battery to connect to the ESC, do I need to solder the female version of the connection my battery uses to my esc? Here are the links to my esc and battery. Thanks.
http://hobbyking.com/hobbyking/store..._ESC_2_3S.html
http://hobbyking.com/hobbyking/store...Ah_2S_20C.html
SeanConn1 is offline Find More Posts by SeanConn1
Old Jun 16, 2014, 07:18 PM
Back in the air
United States, CO, Pueblo
Joined Oct 2013
Yes, I used the same JST Battery Connector. Just cut off the connectors from the ESC wires and solder on the female JST Connector. Make sure the polarity of the female connector matches the battery. The connectors that I got the red and black wires are reversed.
vancamp34 is offline Find More Posts by vancamp34
Old Jun 16, 2014, 07:54 PM
Joined Oct 2013
Was not expecting such a fast response. Thank you so much!
Old Jun 16, 2014, 09:48 PM
tallflyer's Avatar
Joined Jul 2002
SeanConn1
I can get you a 10amp esc that has everything soldered ready to go if you live in the USA for under $15 plus Shipping.. let me know if you still need help.... otherwise your on the right track...
Old Jul 03, 2014, 06:10 AM
Perth, Ballajura
Joined Oct 2007
Built one of these today. I built it and then screwed up a little so i started over. So glad i did, learned a fair few little tricks. I made it from 6mm depron as thats all that is available near me atm (Supplier forgot to order 9mm last order). As it is a bit thinner i added some more carbon bracing. It's very strong and should be fine. Time will tell.
Placed my Hobbyking order, got the following:
Turnigy 2730 1500kv Bell style.
3x HXT900 servos (they're out of 500's)
Turnigy Plush 12A esc
FrSky Delta 8ch Receiver S-FHSS (Yes i am one of few who hasn't converted to spektrum XD)
GWS 8040 Prop (I got loads on 9050 props which ill trial. I don't think i need the extra thrust and don't want to load the motor too much.
Zippy 350mah 3s Lipo
and other things, jst connectors, clevis, pin horns, motor mount.
Here's some pics of the build. I sanded everything to remove rough edges.
brendonv is offline Find More Posts by brendonv
Old Jul 03, 2014, 08:13 AM
tallflyer's Avatar
Joined Jul 2002
Looks good keep us posted...
Old Jul 03, 2014, 10:02 AM
Perth, Ballajura
Joined Oct 2007
Will do. 3 weeks time i should receive my order and then ill chuck up a video. Just added a bit of paint to the top of the main wing and elevator. Using hobby diacast enamel paint (humbrol), I believe it is actually thinners based but i tested it on a scrap piece first and lots of thin coats didn't damage the foam at all. Used yellow, red and black so its nice and vibrant. Stay tuned.
EDIT: Here's a video i made of the build
SuperSlo28 Build | R/C 3D Foamie plane (8 min 41 sec)
And a picture after paint. Not the best paint job but didn't want to add to much unnecessary weight.
Old Jul 14, 2014, 10:36 PM
Joined Jan 2014
tallflyer,
Thanks. Received my servos and motor mounts Saturday.
I don't know if this has been posted and I apologize if it has. For the superslo, you can sub the 20-30 inch pushrods with rc car antenna tubes. They are about 12 inches long, leaving just enough at both ends. They come in several colors. Also they are only $1.19 instead of 6-7$. Of course you need the wire, but that's cheap.
Joe
Joval is offline Find More Posts by Joval
Video Slofly28 Superslo tallflyer Electric Plane Talk 2 Nov 15, 2008 10:01 AM
Sold Slofly28" Superslo kit tallflyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2008 10:33 AM
Sold 1 Slofly 28 SuperSlo kit, 1 Slofly 28 Acro, 3 GWS Pico servos - $45.00 shawn595 Aircraft - Electric - Airplanes (FS/W) 6 Jul 25, 2008 12:26 PM
