Old Jul 10, 2013, 11:57 AM
Allways the hard way!
georgy's Avatar
South Africa, GP, Germiston
Joined Jan 2012
Question
Lanyu 40 stik on 4250 500kv ok?
asked elsewhere but
Will a 40 size Ugly Stik go ok on a 4250 500kv set-up from my recently deceased 1450mm w/s FMS Mustang? (On 4cell, FMS 50A esc)
Looking at converting a nitro Lanyu 40 stik...
any thoughts please...
thanx
George
georgy is offline Find More Posts by georgy
Old Jul 11, 2013, 06:38 PM
Joined Dec 2009
It should work, but you may not get the performance you want from it. The KV on the motor is kind of low, but it was needed on the mustang because of the big 3-4 blade prop that was on it. I think you would be happier with it if it had a 700-800kv instead of the 500kv.
jstern429 is offline Find More Posts by jstern429
Old Jul 12, 2013, 11:19 AM
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
I have a 5lbs WWI bipe with a 550KV motor on 4S, I need a 13x8 to get decent power out of it on 4S, and it is a little hard on my aging $3 4000mah 90c batts.
If your plane isn't draggy and is more like 4lbs you'll get a little better than scale power, but it won't be real sporty.
40 size with 4S on 770kv has a good bit of spirit.
CNY_Dave is offline Find More Posts by CNY_Dave
Old Jul 12, 2013, 01:44 PM
georgy's Avatar
Joined Jan 2012
Thanx for the reply gents.. Even in the Mustang i found it a marginal.. Guess that plan is not gonna work well then... I want some spirit in the stik!
George
Old Jul 12, 2013, 02:33 PM
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
think 5 cells then with the 500 kv motor
scottc39 is offline Find More Posts by scottc39
Old Jul 12, 2013, 03:53 PM
Joined Sep 2010
I recently acquired a pair of 5S batts and there's room in the bipe, a few tweaks and I'm going to be 5S also.
That way my 4S batts will survive to power my sig LT-40 (if/when I ever build it)
Old Jul 14, 2013, 06:09 AM
Learn to build with wood.
Tucci's Avatar
United States, NC, Newport
Joined Sep 2012
I'd go 5s with that on a 13" prop. I think you'll be very happy with it. I have a couple 40 trainers I converted. I use 5055 motors 500-670kv on 5s with 12x8. These puppies weigh 6-7lbs and they are animals as far as power goes.
Tucci is offline Find More Posts by Tucci
Sold Fms 4250 500kv motor, and 2216 1250kv T-motor- $35 Also G15 and 40 amp Esc-$40 copperbricks Aircraft - Electric - Power Systems (FS/W) 0 Jun 08, 2013 08:45 PM
Sold FMS 4250 500kv brushless motor never used ryramZ Aircraft - General - Radio Equipment (FS/W) 2 Apr 12, 2013 11:41 PM
Sold Airfield/FMS 4250-500kv Brushless Motor constantmotion Aircraft - Electric - Power Systems (FS/W) 1 Feb 26, 2013 04:11 PM
Sold Airfield / FMS 4250-500KV Brushless Motor & 50AMP ESC **V3** SOS-TopGunsBro Aircraft - Electric - Airplanes (FS/W) 0 Jun 17, 2011 04:39 AM
Sold Airfield / FMS 4250-500KV Brushless Motor & 50AMP ESC **V3** SOS-TopGunsBro Aircraft - Electric - Power Systems (FS/W) 0 Jun 17, 2011 04:36 AM
