Old Jun 22, 2010, 04:45 PM
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
DVR with screen
I really need to get a DVR with a screen now but Im finding it real hard to find anything anyone is satisfied with so I was hoping someone would give me a suggestion here.
Any suggestions is much aprechiated!
malcr001 is offline Find More Posts by malcr001
Old Jun 22, 2010, 04:48 PM
Bandarra's Avatar
UK, South Yorkshire, Sheffield
Joined May 2009
Vivitar DMD-P20.
bought used from amazon for 10. is amazing. 20Gb storage. large screen very bright picture, sometimes i wonder if not better than the goggles. SD card slot. can record and watch live. playback too etc etc.
best value for money ever
Bandarra is offline Find More Posts by Bandarra
Old Jun 22, 2010, 04:49 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
What recording bitrate?
Does it record through static?
Example vids posted?
ian
Daemon is online now Find More Posts by Daemon
Old Jun 22, 2010, 05:11 PM
Slower Traffic Keep Right.....
Teamwoody's Avatar
Pleasanton, Ca
Joined Feb 2007
I love my Archos AV500 30 gig PVP. Its worked flawlessly since I bought it brand new 5 or 6 years ago. I've heard they can be obtained via E-bay for about $100.00 give or take.
Teamwoody is offline Find More Posts by Teamwoody
Old Jun 22, 2010, 06:50 PM
malcr001's Avatar
Joined Nov 2007
Thanks for the help guys! I went with Teamwoodys suggestion and got a 2nd hand Archos AV500 100gb for 125 at Amazon.
Old Jun 22, 2010, 08:20 PM
So Cal FPV Aviator
EyeFlyPlanes's Avatar
USA, CA, Santa Clarita
Joined Feb 2008
Does it record through static? Do u have a sample video?
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Jun 22, 2010, 08:25 PM
My other plane is the TARDIS
jbpilot's Avatar
Philly 'burbs.
Joined Feb 2009
FWIW, I use an older Aiptek Personal Media Player. Nothing fancy. It records through static just fine and in fact has been great with troubleshooting known dead areas. Only negative is that in bright light it's somewhat hard to see the screen. That is probably common of most solutions though.
JB
jbpilot is offline Find More Posts by jbpilot
Old Jun 22, 2010, 08:49 PM
malcr001's Avatar
Joined Nov 2007
JB
Yer thats pretty common with a lot of devices with screens unless its e-ink!
Old Jun 22, 2010, 09:11 PM
Teamwoody's Avatar
Pleasanton, Ca
Joined Feb 2007
Yes the Archos AV500 records through static, sorry I dont have any videos showing that. The sample video below is not de-interlaced.
FPV EasyStar Flight (17 min 28 sec)
Old Jun 23, 2010, 01:31 AM
So Cal FPV Aviator
Joined Feb 2008
It seems as if the video is a bit small? Like 320 x 480. Recorder setting?
Old Jun 23, 2010, 12:57 PM
Bandarra's Avatar
Joined May 2009
Originally Posted by daemon View Post
what recording bitrate? dont know exactly. It is in mp4, at 7xx by 4xx. At 25 or 30 fps, not really sure
does it record through static? yes
example vids posted? yes
ian
By the lake (2 min 8 sec)
Has some static in the middle of it if I remember correctly.
bare in mind that the "bad" quality of the picture is due to the camara ( really cheap 380 lines one) and all the format conversions and movie maker and youtube.
cheers
ps. it cant start recording from static, says it cant find a source. but if you have a picture and then go static is keeps recording and displaying the static
Old Jun 28, 2010, 02:11 PM
malcr001's Avatar
Joined Nov 2007
Just to let you guys know I went with the AV500 and it serves me well:
Pros:
built in screen
Serves both as a DVR and MP4 player
Can sort,edit files
Serves me well for other purposes for watching any pics or movies
It looks like its easy to change the hardrive as the back plating (battery) comes off just by sliding the button
Audio recorder
Built in speaker and microphone
Cons:
My only complaint is the poxy docking pod which contains all the connections like AV in/out, s video etc. I think this should be intergrated into the DVR and to actually use it you must connect it to a power source. Note if you do get one you need one of these so you can connect to AV/OUT in the field without needing to connect to a power source.
http://www.amazon.co.uk/gp/product/B...ef=oss_product
Not a huge selection of DVR settings but mine are on highest which is:
Bitrate(can be edited): 2500 kb/s
Res at 640 x 480
Saved as AVI
Havent had any problems with recording.
Prior to this I had the easycap USB but after my first attempt at flying on the field I found out although its a cheap solution that can work just as good I had the Ulead software playing up on me and comming up with a corrupted file message. I also decided not to use virtualDUB at the time since it requires time to setup as it doesnt save youre settings. All that time I could be flying instead so I gave up trying to record it. This DVR solution works well for me less wires, less space in my bag and it does its job!
Old Jun 28, 2010, 03:44 PM
malcr001's Avatar
Joined Nov 2007
This is the unedited uncompressed sample video I made just walking round garden. Big difference compared to all these youtube vimeo compressed videos IMO.
http://imagine-that.co.uk/VID0002.AVI
Old Jun 28, 2010, 05:18 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Doesn't exactly blow me away though.
Any recorder can handle low motion (holding still in front of a cat on the ground).
FPV recorders need to handle both high motion and high detail, which is
the worst case scenario for digital video compression.
A snapshot from your clip while walking across the lawn shows major compression
artifacts. Lots of square blocks where there should be high detail, because
it just doesn't have the bitrate to handle the moving details.
ian
Old Jun 28, 2010, 05:25 PM
malcr001's Avatar
Joined Nov 2007
ian
Just a note I didnt record it for this post it was in my DVR so I thought Id post it which is why I used the word sample. I thought it was fine but you seem better suited to making the judgement but I must admit it doesnt look so good in a frozen frame.
Have you got a DVR that works better for you?
Question did your dx6i come with plastic over the screen? drewwrx Electric Plane Talk 7 Jun 16, 2010 07:13 PM
Discussion Cellpro 4S with upgraded LCD (OLED) screen dying. MrRetro Batteries and Chargers 6 May 10, 2010 10:49 AM
For Sale Mini Keychain camera with memory DVR alexedit Aircraft - General - Miscellaneous (FS/W) 3 May 06, 2010 05:49 PM
Discussion New receiver/dvr/lcd screen on dx arkcom FPV Talk 1 Oct 25, 2009 09:43 AM
