Old Mar 20, 2014, 11:41 AM
wltoys v959 / jamara q-drohne
gamer06's Avatar
Portugal, Viseu District, Viseu
Joined Jan 2014
Replace receiver board wltoys v959
had a problem with my original receiver, and bought a new, what happens is that not binds with the TX , any thoughts?
the new one is just like the old one.
http://www.aliexpress.com/item/V959-...880895373.html
the original receiver brokes because I tried to measure the voltage output for an motor output plug and i have a dead short and began appearing a little smoke, only one output to the motor is faulty which was moreover works normal if there plug an motor in this plug it starts to rotate slowly regardless of control that given with the TX.
gamer06 is offline Find More Posts by gamer06
Old Mar 20, 2014, 02:52 PM
United Kingdom
Joined Dec 2012
The image seems to be of the V959 board, but can you confirm you've been sent the right one; IE not a V222 board?
This has happened a couple of times to members of this forum.
ZeRoEXPO is online now Find More Posts by ZeRoEXPO
Old Mar 20, 2014, 07:26 PM
gamer06's Avatar
Joined Jan 2014
They are equal i don't understand why the tx does not bind to it, the receiver of the V222 is green, the v959 is blue they have very differences.
Someone?!
Old Mar 24, 2014, 09:22 PM
gamer06's Avatar
Joined Jan 2014
finally got it, it's working. I searched on google and found someone to review: 1-turn the quad upside down 2-connect the battery and then quickly the transmitter. And it worked, now i did it in the standard position and always works. I don't know if it was trying this way but it is working.
Discussion Can I control a WLtoys v959 with a frsky taranis and no module? groncho Mini Multirotors 2 Nov 21, 2013 03:29 PM
Discussion WLTOYS V959 Unboxing First impressions makuloco2000 Mini Multirotors 3 Oct 18, 2013 07:56 PM
Help! Wltoys V959 Upgraded V222 6-Axis RC Quadcopter problem! salamala Micro Helis 7 Oct 12, 2013 11:19 PM
Discussion Does the WLtoys v959 bind to the frsky taranis? groncho Mini Multirotors 0 Oct 03, 2013 10:21 AM
Mini-Review WLtoys V959 Quadcopter with on-board Video old4570 Mini Multirotors 7 Jul 23, 2013 02:57 PM
