Old Jun 26, 2012, 09:53 AM
Build, Fly, Crash, Repeat
Fotophanatic's Avatar
United States, OK, Blanchard
Joined Apr 2012
Question
Battery questions
I have a 900mm quad flying a naza setup with GPS. Whole unit weighs about 5lbs loaded with batteries. Currently using 2 matched Turnigy 6000mAh 25-50C discharge 4 cell Li-Po batteries and getting about 6 to 8 minutes max flight time when I am loaded with a small video camera and a gopro. What would be the best battery setup to get the most amount of flight time? Need as much fly time as possible...
Deon
Fotophanatic is offline Find More Posts by Fotophanatic
Old Jun 26, 2012, 10:00 AM
Merry xmas
KCV6's Avatar
Australia, SA, Edinburgh
Joined Aug 2009
What prop motor combo are you running? Seems a bit short on flight time. I'm well over 5lbs and getting 8 to 10 minutes on 2 x 5000 4S 40C on 800mm (hoverfly).
Mark
KCV6 is offline Find More Posts by KCV6
Old Jun 26, 2012, 10:53 AM
Joined Apr 2012
Running O.S. Motor OMA 3825-750 with APC 12x6 electric props...
Old Jun 26, 2012, 11:07 AM
Merry xmas
KCV6's Avatar
Joined Aug 2009
I'm no expert on the O.S motor but I would think you could go to a 13" or 14" SF prop (13x4.5 or 14x4.7) I could be wrong but for your setup I think you are under propped.
The problem with going bigger on the LiPo's is diminishing return due to the mass. 4S runs at about 100g per 1Ah. I can run 2 x 8000mah 4S 30C packs to increase my flight time by about 4 minutes over the normal 2 x 5000mah 4S 40C packs.
Mark
Old Jun 26, 2012, 11:33 AM
Joined Apr 2012
Mark
Thanks for the info. I'm new to the "big" quads so there has been a slight relearning curve.
Discussion Battery amp draw hexacopter question Reginak Batteries and Chargers 6 Aug 03, 2013 12:01 AM
Help! Motor ESC NAZA Battery question? acuralegendz Multirotor Talk 4 Jun 24, 2012 12:44 PM
Help! Battery question, help... Amps? TBello Batteries and Chargers 10 Jun 23, 2012 07:00 PM
Discussion Couple Battery Questions iBChunkyboy Batteries and Chargers 8 Jun 21, 2012 11:40 PM
Help! Battery question, 11.1 v 12,000 mah??? Wilds315 Multirotor Talk 16 Jun 19, 2012 09:20 AM
