Old Mar 24, 2009, 10:02 AM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
Help identifying motor
I bought this "bell" motor at a swap meet. I'm trying to determine the aproximate KV so I have an idea of what it might be used for. The website didn't help much because the motors aren't shown from behind. Any help is appreciated.
Chris
chris1379 is offline Find More Posts by chris1379
Old Mar 24, 2009, 06:42 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Do you have a tach? Put a couple of of black Sharpie patches on the bell, shine a flashlight at the edge of the bell, run it up on any voltage you wish, measure the rpm.... divide rpm by voltage and that will give you "raw Kv".
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Mar 25, 2009, 01:19 AM
GeorgeM is offline
Find More Posts by GeorgeM
Joined Nov 2008
It looks very much like a towerpro 2408-21.
But go with Dr Kiwi's test to prove it.
GeorgeM is offline Find More Posts by GeorgeM
Old Mar 27, 2009, 05:13 PM
chris1379's Avatar
Joined May 2006
OK, I don't have a tach but I can read the frequency in HZ and voltage while turning with a drill. I found that I can get the voltage and RPM and use the formula Kv = ((RPM/ volt) / 1.41) / 0.95 if I know the RPM. My question is, how do I convert HZ to RPM. It gives pulses on 2 out of 3 cogs of the motor (6 out of 9 poles) so would it be (Freq/6)60=RPM? If so, that's very close to the spec of the drill. It does have the correct number of poles and magnets to be a 2408-21 motor.
Chris
Old Mar 28, 2009, 03:46 AM
GeorgeM is offline
Joined Nov 2008
I don't think your drill test is going to tell you much. A lot of motors from the same manufactures just have a diffferent number of turns to vary the Kv so turning them with a drill would give the same Hz from each but the Kv's would be different.
Just as a reference a 2408 is 23.9mm outside of poles and 6.4mm deep. They have an 8mm dia mount.
Old Mar 28, 2009, 04:36 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Don't worry about its KV..just fire it up ion a 6x4 first, on 3s. and go up till you get to about 12A or so. That's a reasonable max for something like that.
Old Mar 28, 2009, 08:38 AM
chris1379's Avatar
Joined May 2006
Right, but a different number of turns will give you a different voltage output at a given speed. It's on THIS PAGE about winding your own motors. I think I'll just take it to the shop sometime where there is a vice, a tach, and lots of other stuff that measures.
Chris
Old Mar 29, 2009, 08:33 PM
GeorgeM is offline
Joined Nov 2008
I guess the formual from that page may give you a very rough idea but you still need to know what max current draw is for that motor before you decide what to use it for.
Old Mar 30, 2009, 08:40 PM
chris1379's Avatar
Joined May 2006
Mystery solved
Mystery solved. I took the motor in to the shop today and did 2 tests. For the first test, I ran it up to full speed, tached it, and measured the voltage. I came up with 13636rpm / 9.35V = 1458KV. For the second test, I checked the Speed of the drill, then turned the motor with it. The tached speed of the drill was 1260 RPM. The voltage on one phase was .63 at a frequency of 128 Hz. Using my former calculation of (128 Hz * 60)/6 = 1280 RPM. Very close. From the formula HERE Kv = ((1260/ .63) / 1.41) / 0.95 = 1493 KV. Both answers are reasonably close so I'm going to say it's equivalent to aTower pro 2408-21 .
Chris
Question Help identifying motor 7up Electric Plane Talk 2 Dec 23, 2007 12:38 AM
Please help identifying a motor Cirip Scratchbuilt Indoor and Micro Models 3 Nov 06, 2005 05:49 AM
Need help identifying old Trinity Speed Gems motor???? jschick Electric Power Cars 5 Sep 28, 2004 09:22 AM
I need help with motor timing. jtthebiggafigga Electric Plane Talk 3 Jun 09, 2001 11:12 PM
