Old May 14, 2001, 06:49 PM
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
How many amps on a S600?
Ok, here's the deal: Another club member of mine, after hearing me complain that I didn't have a plane that could handle any more wind than 5 or 6 mph (all I have is my trusty full fuse lite stik), he dedided to give me a PT-Electric that another club member had given him a while ago (w/o radio equipment, of course). So, for my current building project (a speed 400 super cub) I have a 555 reciever and 2 HS-81's lying around, and they don't look like they will be getting used for a while. So I now have a plane (w/ speed 600 motor), a reciever, and 2 servos! what is missing from this picture? A speed control, battery, and a charger. I'm just gonna use a tower 7 cell 1500 mAh car battery (nice and cheap, only $18), and a cheap hobbico timed charger. I'm not going high quality on this project, I just wanna spend a little bit to get this plane in the air. But my question is this: how many amps should the speed control be? I have an Electrifly c-5 in my lite stik, so I was looking at the c-30 (30 amps). It says that it can handle a speed 600, but I dunno. So, should a 30 amp speed control be sufficient, or should I buy something that can handle more amps?
PunkerTFC is offline Find More Posts by PunkerTFC
Old May 14, 2001, 07:00 PM
Angola, IN USA
Joined Mar 2000
C-30 should be more than enough, as a S600 will burn up with more than 30 amps for any duration.
This application will draw less than that if you keep to an 8 or 8.5 in diameter prop
DPW
dwatkins is offline Find More Posts by dwatkins
Old May 14, 2001, 07:43 PM
Central Lake, Mi. USA
Joined Jan 2001
Buy a Master Airscrew gearbox. 2.5:1 will be fine. Use a 10X7 prop(electric) use 8 to 10 cells, but keep it under 30 amps. This will provide a lot more power and flight time than direct drive. Good Luck !
John
John Zook is offline Find More Posts by John Zook
Discussion razor 2500 in GWS EDF-64 = How many amps on 3S? Fiasco Power Systems 3 May 16, 2007 02:18 PM
Discussion How many Amps on B50-8M / 5s Setup f5b@wannabe Hacker Brushless 13 Apr 16, 2007 05:21 AM
Charging batteries on how many amps? larsen2000 Power Systems 2 Aug 22, 2004 01:10 PM
How many amps on EPS300C? Dunqun Batteries and Chargers 5 Sep 25, 2003 10:59 AM
How many amps with a kv 5000 motor, 4.7x4.7 prop on 6 cells? KrisS Power Systems 2 Dec 28, 2002 01:06 AM
