Old Feb 06, 2014, 02:07 AM
Joined Jan 2010
Build Log
Skipper buil by JF Jet Studio-latest video
Recently moved house, finding much nicer beaches to fly my jets and as a bonus I got also at my door step large lake I found it could be an ideal place for sea or float models I have never got chance or desire to fly in the past. Being EDF and turbine specialist now days I have some experience flying large scale helicopters off the water but itís a time to try something different, so after some inquiries I got my hands on HK Skipper to start with.
Being a cheap ARF foamy built by some factory workers who probably never visited flying field or seen model aero to fly the first thing I have found after some brief inspection this model wouldnít last one flight. So I ripped out all the plastic horns from control surfaces. There was so much of play that it simply would not work. Ply wood sheeting blocks will be in-bedded into the foam before the horns are fitted back for precise controls so I can enjoy flying this model for many years to come. Using 5 and 15 min. epoxy the whole model is being put together. To get better bonding, all join surfaces are pinned with the pointer. Probably the easiest model to put together makes it even more exiting for impatient builders. I have hook it to two transmitters one using traditional 5ch FM RX. and other one 7ch 2.4 GHz RX. to centre and adjust all servos. Throttle didnít need any adjustments working great the full range so the next step was some static testing. Using 2.2Ah 30C pack the full stick current was 20A/228Watts, at Ĺ it drew only 10A/110Watts. Under the load it read 11.7 V with 3S batt. After some flying using the stock set up I will experiment with some upgrades so stay tuned for more results. Before maiden Iím going to give it bit of hand paint job to make it look my way. J.
jofro is offline Find More Posts by jofro
Old Feb 07, 2014, 01:26 AM
Joined Jan 2010
Not in any hurry, finding bit of time to do some improvements, J.
Old Feb 08, 2014, 03:54 AM
Joined Jan 2010
Touch of colour for better orientation, just about ready for some range checks and test flights, J.
Old Feb 08, 2014, 08:34 PM
Joined Jan 2010
To minimize possibility of water getting in I sealed off all joints on the belly and the top of fuselage using white silicon. After unsatisfactory range check with 5ch. FM RX I switched to 9ch. SPCM RX I find fool proof for anything up to 6S. J.
Old Feb 09, 2014, 03:55 PM
Joined Jan 2010
I logged my first flight this morn by hand launch, little shocked how sensitive all controls were despite less than half of recommended travel. 25-30% TA is probly all I need for enjoyable flying. Lively model all I can say. Just bought a small alum boat with 3HP out board I will dolly to the ramp loaded with picnic, fishing rod, "Skipper" and my darling. Looking forward to it, J.
Old Feb 16, 2014, 02:05 AM
Joined Jan 2010
After few flights of getting used to it by hand launch, I took it out for the test flight off the water in light drizzle. All went brilliant as expected, tho more modifications needed for better manouvrebility while taxiing. Stay tuned, J.
Old Feb 22, 2014, 01:17 AM
Joined Jan 2010
My latest addition to the Skipper is rudder with more authority while taxiing in the water, works wonders, J.
Old Mar 02, 2014, 04:47 PM
Joined Jan 2010
Despite the wet weather we are presently experiencing the bird is pushing it's limits even in the light drizzle, so far so good. Too dull for the video so hopefully the sun will shine again soon, J.
Old Mar 21, 2014, 03:00 AM
Joined Jan 2010
Latest video action next, stay tuned, J.
Old Mar 23, 2014, 04:40 PM
Joined Jan 2010
Latest footage and the tightest landing!, Enjoy, J.
P1060344 (3 min 52 sec)
Old Apr 08, 2014, 09:56 PM
Joined Jan 2010
Off to the flying field, this time with some fishing gear as well, J.
Old Apr 09, 2014, 09:53 PM
fairplane's Avatar
Canada, SK, Prince Albert
Joined Aug 2006
You're making me jealous! The snow is finally melting here. Your Skipper looks great!
fairplane is offline Find More Posts by fairplane
Old Apr 10, 2014, 02:49 AM
Joined Jan 2010
Get some ski jumping gear and off to the Calgary ski jump, my favoured. Today went fishing, no fish but great flying instead, J.
Old Apr 19, 2014, 01:42 AM
Joined Jan 2010
What a perfect Easter Saturday, bit of fishing, BBQ lunch at the beach, afternoon siesta and finishing it off with few Skipper flights still in one piece after almost 100 flights logged, J.
Video "HARRIER" modified by J. F. Jet Studio jofro Foamy EDFs 8 Aug 23, 2013 03:15 AM
Build Log Little "SEA VIXEN" build by J. F. Jet Studio.- Latest video jofro Foamy EDFs 20 Aug 23, 2013 03:10 AM
Sold Jet Central JF-170 Rhino gjhinshaw Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 14, 2010 12:45 AM
Sold Jet Central JF-170 Rhino NEW 0 time! gjhinshaw Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 14, 2010 12:43 AM
Wanted Swap or sell Jetcentral Falcon JF 100 Titanium turbine for Jet Central Rabbit Mavrik Aircraft - Fuel - Jets (FS/W) 0 Oct 29, 2008 05:11 AM
