Old May 27, 2013, 01:39 PM
Dr Komet's Avatar
United States, CA
Joined Mar 2005
Help!
Looking for APO3 motor alternative
Hi,
I am looking for a 1 cel alternative to the Hobby King APO-3. We need a motor that delivers an honest 40-45 grams of thrust on a 3" prop. I bought the APO-3 and did a group build Micro F-22 ParkJet based on it but we have had nothing but trouble. The best we have seen has been 30 grams of thrust trying a variety of ESCs and batteries. Perhaps we got a bad unit. I have heard of poor QC.
Does anyone have a similar experience or better motor recommendation?
Thanks...
Dr Komet is offline Find More Posts by Dr Komet
Old May 27, 2013, 03:51 PM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
a few details will help us determine the best solution, like what Kv version did you try, what pitch props were you using?
i'm not sure if your f-22 has room for it, but it seems many users on HK had better results with a 4025 gws prop. might be worth a try before going to another motor.
derk is offline Find More Posts by derk
Old May 27, 2013, 04:04 PM
Joined Jan 2005
Ap05
I believe the AP05 brushless motor will put out that kind of thrust on 1S
not sure there is a high kv version which you will need with such a small prop.
scharlach is offline Find More Posts by scharlach
Old May 27, 2013, 04:39 PM
Dr Komet's Avatar
United States, CA
Joined Mar 2005
Hey guys,
Thanks for getting back... I knew that I was missing something when I hit the SEND button!
I have the 7500 kv version APO-3 and was running the GWS 3 x 3. We have tried others. Need 3.5" or smaller diameter prop to fit in the fuse.
Ps: Super cool servo mods. Scharlach!
Old May 27, 2013, 04:43 PM
Joined Jan 2005
Adc5
You might also want to check out the HK ADC5 motor as it has a 3900kva.
Old May 27, 2013, 05:11 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
AP05(5000kv) with a 3.5'' prop will be close to what your looking for. If it has a Star wind you could change it to Delta for a higher KV. If you decide to go 2-cell this little gem will really get you going.http://www.microbrushless.com/productstj.htm
TODD
I R Irv is online now Find More Posts by I R Irv
Old May 27, 2013, 06:28 PM
Dr Komet's Avatar
United States, CA
Joined Mar 2005
Great!
I see the HK ADC5 on the HobbyKing site and the Mighty Midgets look excellent. Thanks!
Has anyone played with helicopter motors for airplane applications?
It seems like this high KV motor designed for 1 cel - S5 helicopter motor has potential:
http://www.hobbyking.com/hobbyking/s...elicopter.html
Any reason not to use helicopter motors in planes? Thanks for the good tips!
Old May 27, 2013, 06:40 PM
Oak Ridge, Tennessee
Joined Dec 2007
The HK 1608 5900kv outrunner might work for you, it is stronger than the AP03. I've used it on a couple of planes with good results. I have not measured the thrust, and I am using 3.5 to 4.5" props. A 3" would really scream, if it would fit the prop saver. I used smaller screws and ortho rubber bands on mine.
The MM motors are very good too, but I have not seen them available lately.
shagrug is offline Find More Posts by shagrug
Old May 27, 2013, 08:28 PM
bselman's Avatar
sw missouri
Joined Sep 2001
Check here for the MM motors: http://www.homefly.com/products.asp?id=43
Bob
bselman is offline Find More Posts by bselman
Old May 27, 2013, 11:48 PM
Dr Komet's Avatar
United States, CA
Joined Mar 2005
Thanks Bob!
Old May 27, 2013, 11:50 PM
Dr Komet's Avatar
United States, CA
Joined Mar 2005
Hi Shagrug,
Thanks for the tip on the HK 1608 5900kv. I'll check it out!
Old May 28, 2013, 06:19 AM
bselman's Avatar
sw missouri
Joined Sep 2001
Check out Oversky RC. They have some very high Kv motors in the -03 size.
HP03 with13500Kv to 16600Kv; and there is an HP02 with a 12000Kv.
http://www.overskyrc.com/index.php?m...dex&cPath=1_16
Bob
Old May 28, 2013, 02:25 PM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
If you go the Mighty Midget route, I recommend the "Single Cell Hot Wind" !!!
From the microbrushless.com website:
Mighty Midget 13/3/12- This hotter wind has been optimized for the FR/AW 220-250mahr cell when propped with a GWS 5*3, or 6*3 prop.
(Measurements at 3.5V )
Prop Amps Thrust RPM
GWS 5*3 1.77 51.5g 7720
GWS 5*3 n 2.29 61.3g 6450
356Jim is offline Find More Posts by 356Jim
Old May 29, 2013, 07:49 AM
Dr Komet's Avatar
United States, CA
Joined Mar 2005
Thanks guys. I'll check them out! Any thoughts on using the high KV helicopter motors in airplanes with a small prop? I am stuck at 3.5" max diameter. Thanks
Old May 29, 2013, 05:21 PM
COPENHAGEN DENMARK
Joined Aug 2007
There is a "secret" MM motor for 1 cell 13/4/10 D give 105g thrust with a good ESC. You can order from HOME FLY, but you need a bigger prop.
John
johnkielsen is online now Find More Posts by johnkielsen
Help! Alternate Motor for Mini Pusher Jets crxmanpat Pusher Prop Jet Models 17 Apr 04, 2013 08:41 PM
Question Alternative props for Xaircraft motors Greiswig Multirotor Talk 2 Apr 03, 2013 10:02 AM
Discussion Alternative prop mount for NTM Prop Drive 35-36A 910Kv motor? nikivan Multirotor Talk 7 Feb 20, 2013 09:43 PM
Help! Looking for Cheaper Alternative Dome for MK Hexakopter in the UK Sebbie Multirotor Talk 3 May 12, 2011 11:20 AM
Wanted Looking for alternative wing for Eflite Ascent? fabmaster911 Aircraft - Sailplanes (FS/W) 2 Jun 03, 2010 09:34 AM
