Old Jan 16, 2013, 07:39 AM
Joined Jan 2013
How can I test the server DELL A930P-00
When you call, without using any connection to the output connector (CN201), the yellow LED warning lights illuminates.
Would, if possible, some guidance for testing the server.
eletmoraes is offline Find More Posts by eletmoraes
Old Jan 16, 2013, 09:15 AM
United States, MN
Joined Feb 2011
Here:
http://www.rcgroups.com/forums/showt...0#post22297886
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 16, 2013, 10:40 AM
Joined Jan 2013
If you make the connections A1 + B1 + B6 as shown in figure must appear voltage of 12V and to trigger the cooler?
Old Jan 16, 2013, 10:43 AM
United States, MN
Joined Feb 2011
Your choice. Use wire and solder carefully. If you can get at bottom of board it might be easier to do there.
Old Jan 16, 2013, 03:07 PM
Joined Jan 2013
I work with electronics and with this source that illuminates the yellow warning LED and would make the same repair. It would help a lot if I could find the schematic diagram of the source.
I did what the colleague suggested but the source provides 12V output only for a moment, and then turns off.
Old Jan 16, 2013, 04:18 PM
United States, MN
Joined Feb 2011
You must connect the source 12v output to charger before connecting AC power.
Old Apr 28, 2013, 12:51 PM
meteor789's Avatar
Poland, Lodzkie, Zdunska Wola
Joined Sep 2008
Hi,
I have the same problem. After ~20 second the yellow led is flashing and it's turns off. Anybody know what should I do ? PS_ON and PS_KILL is connected to GND.
I found this: http://www.rcgroups.com/forums/showp...postcount=1880 , but it isn't working.
meteor789 is offline Find More Posts by meteor789
Old Sep 30, 2013, 06:51 AM
Joined Sep 2013
Dell a930p-00
If you make the connections A1 + B1 + B6 as shown in figure must appear voltage of 12v and then turns off.
Why stops after 10 seconds?
I want solutions did not comment,please...
lukacs is offline Find More Posts by lukacs
Old Sep 30, 2013, 11:58 AM
Canada
Joined Nov 2000
Possibly cuz Dell is lo quality?
Even pre teen boys would never buy Dell anything
Bare is online now Find More Posts by Bare
Old Jan 22, 2014, 08:14 PM
Joined Jun 2010
I got the A930P-00 going by shorting A1 to B1 and shorting B6 to D6
The Z930p links are as mentioned elsewhere in the forum
stewarti is offline Find More Posts by stewarti
Old Mar 25, 2014, 06:06 PM
Joined Jun 2011
I have the A930P-00 also. I am new to this, but am I understanding you correctly?
Shift.Evolve is offline Find More Posts by Shift.Evolve
Old Mar 31, 2014, 04:07 AM
Joined Jun 2010
No Shift.evolve. These are the connections
xxxxxB
xxxxxx
AxxxxB
Axxxxx
I have a Z930P and a A930P.
On my A930P connecting A to A and B to B got it to work. Before I connected B to B as well as A to A it would power up for 10secs then die. Hope this helps.
Old Apr 20, 2014, 01:24 AM
Japan, Fukuoka
Joined Apr 2014
Would you teach me which pin effect for output voltage control?
TINOUYE is offline Find More Posts by TINOUYE
Build Log Converting Dell 7000814 Server Power Supplies wevets Batteries and Chargers 63 Apr 17, 2014 03:27 PM
Discussion DELL SP489 server power supply conversion help? Protoser DIY Electronics 6 Dec 03, 2013 11:17 PM
Discussion Dell server power supply won't provide more than 16amps? davekra Batteries and Chargers 11 Nov 13, 2013 11:11 AM
For Sale Pair of Dell Server Power Supplies ~ $80.00 Bajora Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 12, 2012 10:37 PM
Discussion Power source from Dell server power source jjudd DIY Electronics 4 May 17, 2012 07:47 AM
