Old Oct 28, 2014, 09:12 AM
United States, FL, Miami
Joined Dec 2010
I have a friend that took the middle part off the muffler an just used it as a two piece instead.. He got a new bolt that would fit an hold the two pieces together..
ideas is offline Find More Posts by ideas
Old Oct 28, 2014, 09:30 AM
Joined Dec 2010
Just a few pics of his setup, it seems to work very well, good power only a little louder than normal, but no coming apart..
Old Oct 28, 2014, 01:53 PM
A geriatric flier
Watdazit's Avatar
Australia, NSW, Braidwood
Joined Nov 2008
Originally Posted by flyinwalenda View Post
I understand the stock muffler will come loose if not sealed properly as it did for me. However, after being properly sealed and locked I have two that are holding tight after 3 gallons of fuel and the same goes for many other owners. I'm not sure what some of you are doing or not doing where you keep having stock muffler issues.
I have to say sealing all the joints with silicon gasket compound as well as applying it to the nut worked for me. I also used the gasket compound on the muffler to engine faces, without the standard gasket and worked for me as well. They say tightening up when hot helps but I would have thought the aluminium body would expand more than the steel bolt and hence tighten everything up when hot anyway.
Watdazit is offline Find More Posts by Watdazit
New Product Hangar 9 Meridian Sport ARF and Evolution 10cc Gas Engine Bajora Sport Planes 299 Oct 08, 2014 09:32 PM
Sold Fox 4.2 cu. in. (70cc) gas engine, electronic ignition, runs great barchiola Aircraft - Fuel - Engines and Accessories (FS/W) 7 Nov 19, 2012 07:07 PM
For Sale Evolution 58cc gas engine with new KS header parts and new Evolution tuned canister Daveyboycfs Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 11, 2012 10:07 PM
Sold US Engines NIB 41cc (2.5 cu in) gas engine. REDUCED !! puplover Aircraft - Fuel - Engines and Accessories (FS/W) 0 Oct 15, 2011 01:41 PM
Sold Saito FG-36 4 stroke gas engine (2.2 cu in) James Love Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 22, 2011 11:16 PM
