slowflyer,
I haven't bought any, but apparently Peck-Polymers sell depron in two sheet sizes and a couple of colours. Check out the link: http://www.peck-polymers.com/html/buildmat.htm Gary |
Try emailing these people, they quoted me a price of $60 for 10 sheets shipped to my address, the shipping was around $15 if I remember correctly.
Brent & Maryann Carter bcarter@icgate.net Azarr www.azarr.com |
All you need to do is get some foamboard and remove the cardboard skins. I'm not sure if it's Depron, but if not, it's pretty darn close. You can get thicker stuff at Staples, etc. I found 1/8" foamboard at a local arts and graphics place (Dick Blick, I'm not sure if they're national or not). After removing the skins, the foam is about 3mm, and that seems to be the thickness that people in Europe get their Depron in.
Removing the cardboard skins is easy. Just soak a piece of foamboard in warm water for 30 minutes or so. The bulk of the skin will peel right off. Then, rub the piece with the heel of you hand and the rest will roll right off. Just cut to approximate sizes first since it easier to work with smaller pieces rather than a whole sheet. You can see the foamboard at: http://www.dickblick.com/zz132/02c/p...m=0&ig_id=1013 In the stores, you can buy single sheets. Randy |
