Old Jan 24, 2013, 05:50 PM
froots loops
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
space between arm for 10 inch props ??
can semeone tell me the space betwen arms if I made a chasis that use 10 inch props
like the diji f450 chasis
saskya is offline Find More Posts by saskya
Old Jan 24, 2013, 06:52 PM
Joined Jul 2012
Come on, do you really need to ask kindergarden math on a forum? In the time it took you to write the post, you could have calculated it yourself ten times over, in the time it would take to get a reply you could build the damn frame.
n3mo is offline Find More Posts by n3mo
Old Jan 24, 2013, 08:42 PM
froots loops
saskya's Avatar
Joined Apr 2012
I imagine 450mm
Old Jan 25, 2013, 03:25 PM
Joined Jun 2012
450 / sqrt(2)
rcsnow is offline Find More Posts by rcsnow
Old Jan 25, 2013, 11:06 PM
froots loops
saskya's Avatar
Joined Apr 2012
now here another one
for 29 inch prop, ( crazy )
http://www.rctigermotor.com/
Old Jan 25, 2013, 11:14 PM
United States, TX, Midland
Joined Nov 2006
Depends. Hex?? Quad?? You talking diameter tip to tip? Or one arm to the next tip to tip?
nuttzzy34 is offline Find More Posts by nuttzzy34
Old Jan 26, 2013, 12:55 AM
froots loops
saskya's Avatar
Joined Apr 2012
quad front arms , distance??
Old Jan 26, 2013, 10:02 AM
Joined Nov 2006
Just a bit of Math. You could calculate the smallest you can go and still use 10 inch props. Or just find the distance after a given length of an arm. For example, if it was smallest quad that would use 10s. Plug in 10 for the hypot. Maybe 10.5 for clearance. Then your two, 45 angles since its a quad. Will give you the length of arms. Like n3mo said simple math. I've never built a custom quad before. But I did stay at a holiday inn express last night.
Old Jan 26, 2013, 03:33 PM
United States, NC, Wallburg
Joined Dec 2011
What software are you using to draw out your frame Saskya? I have been working on a Spyder style frame and while it is just math it is nice to have someone verify what your thinking. We all can't be math majors and need a little bit of validation. Good luck with your build and post up some pics.
HeliCopCR1 is offline Find More Posts by HeliCopCR1
Old Jan 26, 2013, 04:49 PM
Joined Nov 2006
Ten in props require a minimum arm length. Of 7.42 inches. Center of frame to center of prop. That's 14.8 or 15 inches diameter from prop to prop center.
Old Jan 26, 2013, 05:10 PM
First quadcopter in space 2014
Full_Tilt's Avatar
United States, FL, Jacksonville
Joined Aug 2012
Dude, make an effort. You are so vague that it is ridiculous.
Full_Tilt is offline Find More Posts by Full_Tilt
Discussion Differences between SF and E Props Witterings Electric Plane Talk 37 May 25, 2013 01:33 AM
Question Differences between bi-blade and tri/quad-blade props karikamiya Scratchbuilt Multirotors 18 Feb 18, 2013 02:09 AM
Sold 10 inch RMC Ground Station Monitor Johnnymeg FPV Equipment (FS/W) 5 Jan 24, 2013 08:59 PM
Sold Dji props 8 inch and 10 inch pmp80 Aircraft - Electric - Multirotor (FS/W) 3 Aug 20, 2012 06:49 PM
Question Minimum spacing between props? spagoziak Multirotor Talk 26 Oct 12, 2011 08:38 AM
