Old Jan 22, 2013, 08:14 PM
Joined Jan 2013
Help!
throttle problems
Hello im sorta new here and i was wondering if someone can help.
i am building my first quad and i having some issues on the set up.
the parts im using are as follows :
hobbyking q450 frame
kk2 flight control board
hobbyking 30A blue esc's
turnigy d2830/11 motors
and the flysky fs-th9x tx and rx
the problem im having is after i setup and calibrate the esc's and test to see if all motors work together i get no throttle response until i move the stick to half throttle
is this normal or am i doing something wrong...
kris255 is offline Find More Posts by kris255
Old Jan 23, 2013, 09:41 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
It doesn't sound as if the ESCs are properly calibrated. Check also your channel ranges in the KK2.0
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Jan 23, 2013, 05:48 PM
Joined Jan 2013
could it be the firmware on the kk2?
i just realized its only the 1.2
Old Jan 23, 2013, 07:11 PM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
It shouldn't be the firmware but if you upgrade to 1.4 or 1.5 the auto level is much improved so worth doing it.
Site Sponsor
Old Jan 23, 2013, 08:04 PM
Joined Jan 2013
ok im waiting for the like to come in the mail thank you
Old Jan 25, 2013, 10:50 AM
United States, WI, Chippewa Falls
Joined Dec 2012
Where's the min throttle setting set to? Also, did you make sure you throttle trim reads 0 on the kk2?
laserj is offline Find More Posts by laserj
Discussion Problems with throttle on Walkera Master Newbie Paul Beginner Training Area (Heli-Electric) 6 Feb 10, 2013 01:17 PM
Sold HPI Baja 5b throttle servo , DS1313 Hi Performance Digital Throttle Servo ronzer Cars - Trucks and Parts (FS/W) 0 Jan 16, 2013 10:32 PM
Problems setting the throttle end points with an ESC. pik20 Power Systems 0 Jun 17, 2002 12:51 AM
Sky Scooter throttle problem GooberVA Foamies (Kits) 4 Jun 02, 2002 03:49 PM
problem: motor cuts off before full throttle davidbogart Parkflyers 16 Apr 13, 2002 10:07 PM
