Old Mar 04, 2014, 10:30 AM
midelic's Avatar
Joined Apr 2012
DIY "FlySkyRX-USB" wireless RC dongle for model simulators
It was brought to my attention an old project PPM to USB adapter.
by Thomas Pfeifer on http://thomaspfeifer.net/ppm2usb_adapter_en.htm
This PPM to USB adapter was used as USB joystick for free RC simulators.Basically any TX with PPM out was hooked to this USB decoder..connected tor PC..and doing RC training on flight simulator.
Furthermore on DIY Flysky thread "plane spotter" was using a DIY Flysksy rx(in PPM mode) and togheter with a PPM to USB decoder(with pic chip)...trained his kids using a free model simulator.
Starting from that,I had an idea. What if we eliminate the PPM(decoder) to USB interface and make one single unit integrated RX to USB.... RC wireless USB joystick for free RC simulators.At the moment only FlysyRx_USB but it can be used any DIY RX in the future.It cannot be used with commercial RX.,,this setup is an integrated unit.There is aready a RCG thread which deal with DIY Flysky Rx ....This setup can be used with any Flsyky transmitter Turnigy9x/Er9x or any Tx with a Flysky module attached to it.
This module is USB powered so no need battery.
During winter and not only ..honing RC flying skills without crashing real tings..but using your original TX
Now:
Hardware:
XL7105-SY module from dealextreme
or XL7105-CL from suntek store.
2.Any setup with Atmega 8/168/328-16Mhz clock
3.USB powered ..and dropped voltage to 3.3-3.4V.
4.Diodes(1N4148) optional if not used voltage regulator
(or voltage regulator any LDO 3,3V...i used LM1117-3,3V)
5.Resistor 68-100ohms -2 pcs
6.Resistor 1.5K
7.Resistor 330ohms-1K
8.LED
Pinout:
XL7105; M8/168/328-16Mhz
SDIO ; B3(11)
SCK ; B4(12)
CS ; B5(13)
GIO;B2(10)
Bind;C0(A0)
LED ; C4(A4 promini)
Vcc ; VCC 3.3v from USB.
Gnd ; Gnd
Clarifications:
1.This setup can be used also with arduino promini or any arduino board with
Atmega328.In this case fuses are already set...
2.If used custom setup with Atmega8 or 328....fuses must be set as following:
For Atmega 8
FuseH=0xC9 FuseL=0xEF(only for M8)
For Atmega328
Low Fuse 0xFF
High Fuse 0xDA
Extended Fuse 005
3.It will work on windows XP/7 including windows7-64 without installing additional drivers.
Schematic is attached.
Later on I'll post one with arduino promini wiring.
Note:
If there is interest in the future Ill extend the support for other RX ....like Frsky RX. for example.
To do:
One version with Frsky rx and openlrs or a multi protocol with all major rx on the market.
Shopping:
XL7105-CL
http://www.suntekstore.com/search.ph...M3MjQ0MTE3Nzt9
XL7105-SY
http://dx.com/s/XL7105
Resources:
http://www.rcgroups.com/forums/showthread.php?t=1921870
https://code.google.com/p/vusb-for-arduino/
http://d-parc.be/index.php/99/2
a list of sims here.
http://www.rcgroups.com/forums/showthread.php?t=1622981
Not all sims will work with this wireless RC-USB dongle.It will work with any RC
simulator wich accept generic microsoft joystick.
Update:
07.03.2014
I managed to finish the RC USB dongle ,I used an existing PLC77/dave board(Flysky Rx),I had .with ATmega 8 ,and installed one 16 Mhz SMD X-tal...Tested ok.Uploaded pics with the final setup.This version used voltage regulator 1117-3.3V
Aileron and elevator was swapped so I fixed.Uploaded new versions.
08.03.2014
Uploaded a diagram with promini .
19.03.2014
For some reason....this code is not working on windows XP.........only Windows7 32/64.
So I hack.... thomaspfeifer ..c code ...and now it is working on all windows versions XP in particular.For some reaso I couldn;t made work the avd-c eeprom routines...so i made version with autobinding. When I have some spare time I'll check again those eeprom routine.
See attached....."FlySkyRX_USB_M8_16Mhz_2.hex."
During winter and not only ..honing RC flying skills or initiating and training your kids, without crashing real tings,but using your original TX.
I think is cool.
Enjoy!
midelic is online now Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
reserved
Latest blog entry: DIY Multiprotocol TX Module
Old Mar 04, 2014, 10:31 AM
midelic's Avatar
Joined Apr 2012
reserved__
Old Mar 04, 2014, 10:39 AM
Austria
Joined Jan 2004
OUTSTANDING JOB !!!
Looking forward for the source code ... I hate HEX files
e_lm_70 is offline Find More Posts by e_lm_70
Old Mar 04, 2014, 10:42 AM
midelic's Avatar
Joined Apr 2012
when you finish the setup I'll give you the source privately.It works on any arduino board with m328 and 16 Mhz.
Old Mar 04, 2014, 02:28 PM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Sweet, when I'm in college next I'll grab the resistors for this, I've got a promini bouncing around doing nothing for the moment, I could hook it up and do the diagram if you like.
What's the purpose of the D4 to D5 1.5k resistor?
djdavies83 is offline Find More Posts by djdavies83
Old Mar 04, 2014, 02:54 PM
midelic's Avatar
Joined Apr 2012
It is pullup resistor for D- ..USB data line.Without that resistor, is not working.
Old Mar 04, 2014, 04:37 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
Ok I understand now, not done any USB projects before this came along. Erg, this "mobile view" looks like my 5 year old designed it.
Edit: I didn't see a upload image link in this "mobile view", really not going to enjoy this if Tapatalk goes.
Last edited by djdavies83; Mar 04, 2014 at 04:39 PM. Reason: Upload image, how is this easier than Tapatalk?
Old Mar 06, 2014, 08:28 PM
midelic's Avatar
Joined Apr 2012
I managed to finish the RC USB dongle ,I used an existing PLC77/dave board(Flysky Rx),I had ,with ATmega8 ,and installed one 16 Mhz SMD X-tal...Tested ok.Uploaded pics with the final setup on first post.This version used voltage regulator 1117-3,3V.
Old Mar 07, 2014, 10:57 AM
plane_spotter's Avatar
United Kingdom, Wrexham
Joined Jun 2004
Not strictly a dongle, more of a hub!!
Just using up some surplus non smt parts. Did not want to hack my PLC77 pcb and run out of m8 smt.
Well it's not pretty but it's up and running. Will glue it into a surplus potting box with a trailing lead.
Will make a small dongle type next time around, perhaps a proper pcb.
Description:
Good work midelic.
m, one thing I did notice when testing in control panel that left stick axis were swapped.
Not got any time now till next week. Busy it's my birthday Monday so away celebrating.
plane_spotter is online now Find More Posts by plane_spotter
Old Mar 07, 2014, 12:00 PM
midelic's Avatar
Joined Apr 2012
Ash,
I tried on 2-3 sims and it appears to be ok,
Try on a real ...sim and ....select the channels.
Ash,
Happy Birthday!
Old Mar 07, 2014, 03:07 PM
midelic's Avatar
Joined Apr 2012
Ok fixed the swap...Uploaded new version on first post.
Old Mar 07, 2014, 05:40 PM
Joined Jun 2004
Thanks m, another year wiser.
Will try next week, thanks.
Ash
Old Mar 08, 2014, 09:18 AM
Austria
Joined Jan 2004
Attachment 6570690
Good work midelic.
Good job.
Would it be more simple to use just arduino pro mini board compared to use a naked ATmega chip ?
I think it will be cheaper too
Old Mar 08, 2014, 10:46 AM
midelic's Avatar
Joined Apr 2012
When I test first time I tested on promini board .Yes of course,...anybody can use promini but16Mhz ..on 8 Mhz not working.
Help! 20 in 1 Flight Simulator Cable/USB Dongle for RC Helicopter Realflight AeroFly snakecrew Simulators 4 Dec 25, 2013 12:29 AM
Discussion jmt 12 in 1 wireless RC USB thosmosis Simulators 3 Oct 29, 2013 04:48 PM
Discussion USB 2.0 Almighty Flight Simulator Dongle Imom Electric Heli Talk 3 Jun 06, 2011 04:02 PM
Discussion Phoenix USB dongle with FMS and Flight Simulator X Lon33 Simulators 8 Dec 29, 2008 09:00 AM
Wanted Reflex Xtr simulator with USB dongle tran3633 Aircraft - General - Miscellaneous (FS/W) 0 Jun 23, 2006 07:02 PM
