Old Dec 06, 2009, 11:16 PM
Flash, AAAAAAAAAAAHhhhhhhhhh
flashkick's Avatar
United States, UT, West Jordan
Joined Dec 2008
30mm edf
does anybody know of a 30mm edf that is reasonably easy to find? price isn't a problem and i need something that gives more than 100g of thrust, i would like closer to 130g. and it need to work with 2s. or if i can get one to get over 150g with 3s. i know nitro's fan gets about that but i can't find where to get those. so any suggestions?
flashkick is offline Find More Posts by flashkick
Old Dec 06, 2009, 11:52 PM
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
When you find one, please post for the rest of us, because Nitro's fans were the only fans capable of your requirements. Good luck.
boredom.is.me is offline Find More Posts by boredom.is.me
Latest blog entry: RFD900 Case
Old Dec 07, 2009, 04:54 AM
Nothing flies like a Pitts
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
Does it have to be 30mm? It is Much easier to get that amount of thrust with 40mm + (+33% more duct area also mean that you dont need to go that hard on the motor)
Meshuggah is offline Find More Posts by Meshuggah
Old Dec 07, 2009, 06:57 AM
It's a spiderweb of knit lines
Souderton Pa. USA
Joined Mar 2002
Do you realize what the current will be at those power levels?
mcross is offline Find More Posts by mcross
Old Dec 07, 2009, 07:34 AM
flashkick's Avatar
Joined Dec 2008
okay thanks it looks like i'll be going with a 40mm fan.
Old Dec 07, 2009, 11:47 AM
stegla's Avatar
Guernsey
Joined Jan 2002
The kp32 would fit your requirements. Derek of kpaero will ship to the US but I guess it might get expensive?
http://www.kpaero.com/ProductReport....gory1=electric
Steve
stegla is offline Find More Posts by stegla
Old Dec 07, 2009, 05:39 PM
Meshuggah's Avatar
Stockholm, Sweden
Joined Aug 2006
The general "problem" when things are getting to small is that it is ineffective (draws allot of current, get hot etc) and the difference getts to big (40mm is like 100% more duct-area than 30mm) If you go with 30mm, BUILD LIGHT.
It will be very fragile, but it will do the trick. Ratio and friction means everything.
Good luck with your build, Im building a 30mm ducted jet myself, but it will be verry light AUW about 30g.
Old Dec 07, 2009, 08:41 PM
flashkick's Avatar
Joined Dec 2008
ya i looked at all that and it would need to be insanely light and really fragile. hopefully i can make it work. it doesn't need to be very strong it would most likely be an indoor or dead calm flyer.
Old Dec 07, 2009, 09:18 PM
Souderton Pa. USA
Joined Mar 2002
Can you post what you're trying to make?
Old Dec 07, 2009, 10:04 PM
flashkick's Avatar
Joined Dec 2008
its a secret. i won't unveil anything until its close to completion.
Old Dec 08, 2009, 03:59 AM
stegla's Avatar
Guernsey
Joined Jan 2002
You guys should check out pdawgs 'Blowdart' to see what a 30mm edf can do!
150g and 90mph!
http://www.rcgroups.com/forums/showt...light=blowdart
Steve
Old Dec 08, 2009, 06:47 AM
Souderton Pa. USA
Joined Mar 2002
150g and 90mph!
Steve
Yea, but that's a custom built 10mm inrunner motor.
Old Dec 08, 2009, 08:17 AM
byte me!
0011000011001's Avatar
Joined Aug 2008
i thought he was using a losi?
0011000011001 is offline Find More Posts by 0011000011001
Build Log 8'' Micro Jet (L-39 Albatros, MiniDisc, 30mm EDF) Chris T Scratchbuilt Indoor and Micro Models 333 Nov 22, 2012 04:01 AM
Help! 30mm EDF ICS-50Li problems c/f GWS (Grand Wing Servo) 5 Nov 16, 2009 11:10 AM
Question micro pulse unit 30mm edf nadine Scratchbuilt Indoor and Micro Models 1 Sep 24, 2009 12:52 PM
Home Made Brushless Picofan (30mm EDF) Chris T Scratchbuilt Indoor and Micro Models 88 Aug 25, 2006 07:48 AM
30mm Edf Chris Nicastro GWS (Grand Wing Servo) 2 Nov 30, 2004 08:16 PM
