Old Jun 01, 2006, 09:09 AM
ravencsr is online now
Find More Posts by ravencsr
Melbourne, Eastern Sub.
Joined Sep 2004
Question
Spinner on Outrunner Suggestions
Please help !!
My balsa P40 is just about complete, however, attaching the spinner to the outrunner is proving a bit tricky.
I would like to know how other people have done this, or if there are any good products on the market that can simplify the process.
I am using a GWS adapter with a GWS 9x47, with a DuBro 1.75" spinner (see setup photo). The main trouble is the DuBro backplate hole is too big for the GWS adapter. I have search the forums for ideas and all I've found is the following.
It could possibly be solved by gluing a thin ply plate to the front of the backplate and then drill the correct size hole to accomodate the GWS adapter. However the thread on the GWS adapter is very small, I even had to cut some plastic off the prop just to be able to bolt it on. So if I use the thin ply I'm really going to cut it short with the thread.
Can anyone suggest how this could be done? If I was to use a collet type adapter I would need a thead on it about 20-25mm long.
Are ther any other adapters out there that will do this?
Raven.
ravencsr is online now Find More Posts by ravencsr
Old Jun 01, 2006, 09:56 AM
BuzzBomber is offline
Find More Posts by BuzzBomber
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
I think you need an MPJet "long" collet adapter in the appropriate diameter. In the US, you can get them from Hobby Lobby. The outer diameter of the shaft will be very close to the size of one of the spinner inserts, you might need to ream it a little. Also, consider using an APC prop instead--they can handle more power than the GWS props and include the correct inserts to fit the MPJet adapter shaft.
BuzzBomber is offline Find More Posts by BuzzBomber
Old Jun 01, 2006, 10:07 AM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
that spinner should have came with a set of black rings(ADAPTERS) find the one that fits yours and there you go
MustangAce17 is offline Find More Posts by MustangAce17
Old Jun 01, 2006, 10:25 PM
jgmtens is offline
Find More Posts by jgmtens
but it's a nice obsession
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
www.aircraft-world.com has the Hyperion collet adapters that I use with our Dubro spinners. That should be the closest supplier to you that I know of.
jgmtens is offline Find More Posts by jgmtens
Old Jun 01, 2006, 10:30 PM
jgmtens is offline
jgmtens's Avatar
Sandy, Utah
Joined Apr 2003
Here is the page you need.
http://www.aircraft-world.com/shopdi...+PROP+ADAPTERS
Looks like your motor shaft is probably 4mm, maybe smaller. Just pick out the long adapter in the correct size for your shaft. Then use an APC prop or drill out the middle of your GWS prop to fit.
Old Jun 01, 2006, 11:08 PM
euromodels is offline
Find More Posts by euromodels
Sydney
Joined Nov 2004
Prop adaptors
We carry prop adaptors from 2 mm to 6 mm.
Check this website: http://www.euromodels.com.au/shop/in...dex&cPath=4_42
Zdenek
Euromodels
euromodels is offline Find More Posts by euromodels
Old Jun 01, 2006, 11:16 PM
diver don is offline
Find More Posts by diver don
"Each Day Is A Lesson"
diver don's Avatar
Goldsboro, NC
Joined May 2004
As I se it , your problem is trying to use the GWS prop.
As all have suggested, loose the GWS adapter and get the proper collet adapter, and then, using the inserts supplied for the backing plate of the spinner, you will have no problem mounting it.
dd
diver don is offline Find More Posts by diver don
Old Jun 02, 2006, 03:22 PM
BobRCnut is online now
Find More Posts by BobRCnut
AMA 754
BobRCnut's Avatar
Phoenix area
Joined Apr 2004
Hyperion prop adapters, as well as insert rings for the prop hub, are also available from allerc.com .
BobRCnut is online now Find More Posts by BobRCnut
Discussion Mounting Glow Spinner on Outrunner fly4fun Electric Plane Talk 2 Jul 25, 2007 01:44 PM
Help! 2.75" Spinner on a 4mm Shaft - need suggestions tommy321 Scale Kit/Scratch Built 2 Jan 23, 2007 01:10 PM
Discussion How can I mount a propeller and spinner on an outrunner? Dave K Power Systems 3 Dec 06, 2006 07:57 PM
Discussion Formosa spinner on Outrunner GPT Parkflyers 4 Jan 26, 2006 04:35 PM
Spinner on a Mini Laser 3D Michael in Toronto Sport Planes 1 Jul 12, 2001 12:34 AM
