Old Jun 21, 2013, 10:44 AM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Help!
Futaba 7C --- trimming after mixing flaps/airbrake
In order to help with landings on my F-9F Cougar I wanted to mix in some slight up aileron to simulate washout.
Using the airbrake feature I got the flaps, elev & ails all working together when I flip the G switch.
And then I can still dial in more flap the VR knob if needed.
Dialing in the elev trim was simple enough in the airbrake mix. (two servos in one channel on a Y).
It trims out fine for straight and level flight (no flaps), but I'm puzzled at how to trim out the slight aileron roll when the flaps/airbrake switch is thrown.
The ails are on separate servos, one in ch 1, the other in ch 7.
I see the differential mix in the flaprn mix.
But I didn't want to monkey around with anything else until I get some knowledgeable advice.
Boogie_ is offline Find More Posts by Boogie_
Old Jun 21, 2013, 11:28 AM
KingtechUSA
gunradd's Avatar
Tampa FL
Joined Apr 2009
The one to talk to is Bob B.
I have an 8FG on 14 channels and I use the airbrake function to slow the flaps and also add some elevator trim and crow up the ailerons for landing. If your radio programming is anything like mine I can adjust each aileron on how much they go up. Just make one come up a little more then the other to trim it out.
I wish Futaba made a radio with good flight conditions without going to the mega expensive radios.
gunradd is offline Find More Posts by gunradd
Old Jun 21, 2013, 11:37 AM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Boogie_ Here's a link that may come in handy at some point.
http://www.rcgroups.com/forums/showt...w+on+futaba+7c
Step-by-Step: Futaba FASST 7C, 4-servo wing, V-Tail, Crow Complete Guide
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 21, 2013, 01:11 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I had this same issue with my Het F18, what I did to deal with it was I ungrouped my trims so that I had to trim each flight condition seperately this took care of the issue but really something else is the problem like one wing is heavier than the other or right to left wing panel incidence is off or flaps are not dropping an equal amount due to control linkage geometry their can be a few causes anyway not sure if your 7c can ungroup trimming as I am using a 12fg but its worth a shot.
jcdfrd is offline Find More Posts by jcdfrd
Old Jun 21, 2013, 01:24 PM
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
12fg has great programming and great flight conditions.....awesome radio and maybe at one time it was mega expensive but now that they are discontinued you can pick them up used for a great value.
Old Jun 21, 2013, 01:27 PM
KingtechUSA
gunradd's Avatar
Tampa FL
Joined Apr 2009
That is exactly what I am looking for When ever I find a good deal I will pick one up.
Old Jun 21, 2013, 09:42 PM
Da' Cajun
Boogie_'s Avatar
Joined Jun 2009
Thanks for the tips and the link.
I have something to go on now.
Help! Futaba 7C --- trimming after mixing flaps/airbrake Boogie_ Radios 0 Jun 21, 2013 10:43 AM
Discussion Can I mix airbrakes and flaps to throttle clive_fox Radios 8 Dec 10, 2012 02:04 AM
Discussion Futaba 7c 2.4ghz, flap-> elev mixing isn't working. Jarsalla Radios 3 Jul 12, 2011 11:49 PM
Question Mixes and trims on futaba 7c losifanatic Radios 4 Oct 26, 2009 01:38 PM
Futaba 7C, programming Flaps, Airbrakes chris8105 Radios 1 Aug 09, 2008 10:58 AM
