Old Apr 25, 2012, 06:52 PM
Joined Mar 2005
Mark
I had the jr's in and they worked with my 12fg, but I switched them out for the spektrum. Was also using a regular 4.8 rx battery.
Tony
T-spin is offline Find More Posts by T-spin
Old Apr 25, 2012, 07:57 PM
EDF Jet Jam May 2014
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Mark can you run the retract straight the rx? Might be worth checking. Tell DW I said hello.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Apr 25, 2012, 09:53 PM
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
Over the weekend I had a very rough landing, I mean the type you normally write off the plane as trashed and unrepairable. However with the Electra, the only (and I mean the only) damage I got was a broken flex plate on the mains. That's it. Freaking crazy.
Quick call to BVM for replacements, showed up from FL to CA a couple of days later and I'm back in business within 30 minutes.
Wow. I was pretty sold on the Electra before, now I'm a true believer. Thanks Bob for the great idea of using the flex plates to save the planes from more extensive repair work.
sbritton is offline Find More Posts by sbritton
Old Apr 26, 2012, 06:54 AM
Joined Dec 2000
The BVM jets are very well designed. The factory models see many hours of flying every season. Happy to hear it's your new favorite jet.
Old Apr 26, 2012, 08:50 AM
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Bob's right, the reason BVM jets are what they are is because they fly the heck out of them and find issues long before we do. I have to agree, the flex plates have saved my Electra a few times, great design...
Jack
jfetter is offline Find More Posts by jfetter
Old Apr 26, 2012, 03:44 PM
markbrown1's Avatar
Surrey England
Joined Apr 2006
Progress made..... I have changed both mechanical retract servos out and all works fine now.
Does anyone have any comments to make about the Viofan against fitting a Tam Dynamax ? The set up I have purchased is the 10s...
Mark
markbrown1 is offline Find More Posts by markbrown1
Old Apr 26, 2012, 03:51 PM
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
Sound
Neil Guildford is offline Find More Posts by Neil Guildford
Old Apr 26, 2012, 04:40 PM
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Yes, I do... BVM + BVM = Perfection!
Old Apr 26, 2012, 05:14 PM
KingtechUSA
gunradd's Avatar
Tampa FL
Joined Apr 2009
EVF for sure. Its rock solid and does not break. No need to worry about cooling and all the other crap like other fans. They just work day in and day out and perform well no matter how hot it is outside.
If you are one of those sound guys then you can put a Tam120 rotor (dynamax rotor cut down) on the EVF. Then you have the best of both worlds. But I could care less all EDFs sound like well.......EDFs.
gunradd is offline Find More Posts by gunradd
Old Apr 26, 2012, 05:56 PM
Joined Dec 2000
Kris are becoming one of. .....those turbine guys?
Old May 06, 2012, 02:05 PM
markbrown1's Avatar
Surrey England
Joined Apr 2006
I have been looking at the BVM throw settings for the Electra. Does everyone set their Electras up as per the manual ?
Also the 10s Viofan I have fitted in the Electra gave me a watt test at 5000 watts dropping to just below this level ? Is this what I should be expecting from this set up ? It has absolutely bags of power....
Cant wait to fly it later this week if the weather is suitable.
Mark
Old May 06, 2012, 02:16 PM
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
BV posted throws are a bit sensitive to me. I usually start around 80% of what the instructions say..............
gregg f is offline Find More Posts by gregg f
Old May 06, 2012, 02:38 PM
KingtechUSA
gunradd's Avatar
Tampa FL
Joined Apr 2009
I agree with Greg. I rememeber the elevator being pretty sensitive on BVs settings. And I normaly like mine real touchy.
Old May 06, 2012, 04:11 PM
shut up & fly
hoser's Avatar
United States, FL, Miami
Joined May 2001
i flew mine on low rates all the time
hoser is offline Find More Posts by hoser
Old May 06, 2012, 04:13 PM
markbrown1's Avatar
Surrey England
Joined Apr 2006
Thanks chaps.
Mark
Discussion BVM Electra ARF Kevin Murray Electric Ducted Fan Jet Talk 26 Jun 12, 2014 08:13 PM
Build Log BVM Electra ARF build and modifications ralf dvorak Electric Ducted Fan Jet Talk 42 Jan 27, 2012 05:52 AM
Discussion BVM electra/Air blue gear. skyhawk Electric Ducted Fan Jet Talk 0 Apr 25, 2011 05:55 PM
For Sale BVM Electra ARF (RTF) - $4200 chw757s6640 Aircraft - Electric - Jets (FS/W) 11 Mar 12, 2011 09:01 PM
For Sale BVM Electra ARF coupon RicVaughn Aircraft - Electric - Jets (FS/W) 0 Oct 09, 2008 08:43 PM
