Closed Thread
Old Feb 26, 2009, 05:52 PM
heli_ebook's Avatar
Joined Apr 2006
Question
Where does the antenna on a Corona 410ii go?
Once again: the cripple put his toy in a tree! It stayed up there overnight, but was blown down by winds this afternoon. The ant. was completely torn out with NO telltale signs of ripped wiring on the PCB.
Anybody have the ability to photo the PCB close up OR call out EXACTLY
where I need to resolder the ant?
Thank you
heli_ebook is offline Find More Posts by heli_ebook
Old Feb 27, 2009, 06:18 AM
heli_ebook's Avatar
Joined Apr 2006
Great job, kids... keep up the good work!
Old Feb 27, 2009, 01:33 PM
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
There are 2 coils in the corner of the PCB: a big (1mm ) round one on the xtl side and a small blue square one on the label side. Antenna goes to the end of the square one nearest the corner. It is also a point on the big coil but not visible.
Easy if you have jewelers loupe but can be done with naked eye.
If still not sure try a few places and you will see which one gives good range.
Thank you
rich smith is offline Find More Posts by rich smith
Old Feb 27, 2009, 01:38 PM
rich smith's Avatar
Joined Dec 2006
Very good considering what we get paid! Sometimes takes a week to get good answer, sometimes never.
Old Feb 27, 2009, 01:39 PM
heli_ebook's Avatar
Joined Apr 2006
Appreciate your INFO, but it is NOT clear... please respecify.
The OUTER corner of the SMALL BLUE one, is that what you meant
Old Feb 27, 2009, 01:44 PM
heli_ebook's Avatar
Joined Apr 2006
Alright, let's do it this way: Does it go to the OUTER MOST SOLDER PAD which is directly above the CH1 plug, or is it elsewhere?
Old Feb 27, 2009, 02:01 PM
rich smith's Avatar
Joined Dec 2006
Appreciate your INFO, but it is NOT clear... please respecify. The OUTER corner of the SMALL BLUE one, is that what you meant
Yes, end of the small blue coil nearest the corner. No where near CH1 pins. You do know what I mean by coil? It's tricky.
If you post a magnified pic of the label side I'll mark the spot.
These are the best RX on the market.
Old Feb 27, 2009, 02:05 PM
heli_ebook's Avatar
Joined Apr 2006
Ok, so I need to unwrap this thing entirely and lose the heatshrink?
Also, on the label side... there are (2) pieces of gummed foam padding under there. I see NO blue anything on the label side of the PCB.
Old Feb 27, 2009, 02:16 PM
rich smith's Avatar
Joined Dec 2006
Ok, so I need to unwrap this thing entirely and lose the heatshrink?Also, on the label side... there are (2) pieces of gummed foam padding under there. I see NO blue anything on the label side of the PCB.
Yes, shrink off. Coil is near one of the foam pads. maybe the square coil is not blue on yours. Do you know what a coil is? Windings only show a little bit underneath.
There are only 2 coils on the RX. If you can't find them you need to look harder (with magnification).
Old Feb 27, 2009, 02:30 PM
heli_ebook's Avatar
Joined Apr 2006
see below
Old Feb 27, 2009, 02:32 PM
heli_ebook's Avatar
Joined Apr 2006
The main LARGE one on the component side in the corner is obvious, I have yet to find a blue one UNLESS the blue "221" labeled thing is it?
Old Feb 27, 2009, 02:35 PM
heli_ebook's Avatar
Joined Apr 2006
Does this second coil look like a coil, OR like an SMD which is blue?
Old Feb 27, 2009, 02:37 PM
rich smith's Avatar
Joined Dec 2006
Wrong side of the board for one thing. Antenna connects to pad underneath lower rt corner in your pic. You can try several places and see which one works or put a magnifier in front of your camera to get clearer closeup of other side.
Do you know what a coil is? It has windings. There are only two on the board and you need to know where they are. I suggest re-reading the thread after you've done that.
Old Feb 27, 2009, 02:41 PM
heli_ebook's Avatar
Joined Apr 2006
Yeah, BUT There is ONLY the one coil I have found!
Old Feb 27, 2009, 02:42 PM
heli_ebook's Avatar
Joined Apr 2006
Put a RED x on the last photo so at least I know I'm heading in the right direction.
Closed Thread
Help! Where does the antenna go on the Powerhawk PCB Bugman Jeff Micro Ready-to-Fly 6 Oct 24, 2007 05:34 AM
Help! What does this mean on my Corona yaremchl Electric Heli Talk 44 Sep 19, 2006 10:57 PM
Where to put the antenna on the Corona larsen2000 Electric Heli Talk 2 Jul 20, 2004 04:02 AM
Help - Broken Antenna wire on Aeorobird. Where does it attach ? Tipsy_WA Parkflyers 13 Feb 23, 2004 08:55 AM
Where does the antenna go in the Simple? emaij High Performance 3 Aug 04, 2001 12:56 AM
