Old Nov 05, 2014, 06:12 AM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Mini-HowTo
BradWii revolution !! (for toy-quadcopters)
INTRODUCTION
Hi,
First thing, I would like to thanks all Bradwii contributors for this fantastic project: Brad (of course), Victzh, Goebish and the TheLastMutt
Bradwii's goal is to install Multiwii program on dirty cheap FC associated with a lot of toy's quadcoters. For example, a lot of WLtoys and JXD are bradwii compatible. With bradwii, you will be able to tune all flying caracteristics of your quadcopter as well as to be able to add new features since all the sources are available. For less than 7USD, you can transform a cheap FC board into a more Professional one.
Bradwii have been specifically developped to work with the Nuvoton Mini54ZAN, a Cortex-M0 based microcontroller with 16kb of user flash and 2kb of SRAM,, combined gyro/accelerometer InvenSense MPU-6050, and nRF24L01+ clone Beken BK2423. Another variant for the Hubsan X4 is using the Invensense MPU-3050 as gyro, the mCube MC3210 as accelerometer and A7105 as RF.
CAUTION
SINCE WE DON'T HAVE THE ORIGINAL FIRMWARE, IF YOU DECIDE TO INSTALL BRADWII, YOU CAN'T RETURN BACK WITH THE ORIGINAL FIRMWARE !!!
Bradwii tutorial introduction (2 min 25 sec)
REQUIREMENTS
Important links
1) Bradwii installation
a) Flashing tool for bradwii
ST-Link V2 mini
http://www.ebay.com/itm/ST-Link-V2-m...item20ef65de5c
b) Drivers for ST-link V2 mini
http://www.st.com/web/en/catalog/tools/PF258167#
NOT WORKING WITH USB3 port
c) Hooks for an easy wiring
http://www.banggood.com/Test-Clamp-Wire-Hook-Test-Clip-for-Logic-Analyzer-p-936424.html
2) Real time moninoring, parameters settings
a) FTDI to serial converter
http://www.banggood.com/FT232RL-FTDI-USB-To-TTL-Serial-Converter-Adapter-Module-For-Arduino-p-917226.html
http://www.ebay.com/itm/6Pin-CP2102-...item3ce79bff65
Need to be compatible with 3.3V
b) Driver for the FTDI to serial converter
http://www.ftdichip.com/Drivers/VCP.htm
http://www.silabs.com/products/mcu/p...cpdrivers.aspx
c) Mini 1.25mm 4pin connectors (male and female)
http://www.ebay.fr/itm/Micro-Mini-1-...ts_Accessories
3) Keil software/API
a) Main IDE/compiler (mdk512.exe)
https://www.keil.com/demo/eval/arm.htm
b) API for Cortex-M-device
http://www2.keil.com/mdk5/legacy/
4) Bradwii links
a) Last sources of Bradwii
https://github.com/goebish/bradwii-X4
b) Erasing FW tool
https://github.com/hackocopter/JD385_Documentation
iii) Erasing/flashing procedure
https://github.com/hackocopter/JD385...are%20Flashing
5) Multiwii
a) For multiwiiconf (take the last stable V2.3 version)
http://code.google.com/p/multiwii/downloads/list
INSTALLATION VIDEOS
Bradwii tutorial: part-I-software installation (14 min 22 sec)
Bradwii tutorial: part-II-Bradwii installation (13 min 37 sec)
Bradwii tutorial: part-III-Serial configuration and real time monitoring (11 min 27 sec)
More infos can be found at: http://www.rcgroups.com/forums/showthread.php?t=2174365
MINI54ZAN PINOUT & SPECIFIC FC PINOUT
SWD port : Color nomenclature
BLACK = GND, GREY = CLOCK/ICE_CLK, PINK = DATA/ICE_DATA
SERIAL port : Color nomenclature
BLACK = GND, RED = VCC (+3.3V), YELLOW = TX, BLUE = RX
Mini54ZAN pinout
VSS (28) = GND, ICE_DATA (20) = DATA, ICE_CLK(19) = CLOCK
Some FC board have some directly some debug port (at least the SWD one) for an easy connexion (via the 1.25mm JST connector "molex').
If the FC don't have these port but have the correct compatible harware, you need to solder probes directly on the MCI pins.
-V262/V333
-V636
-JXD 392
-SYMA X12
Compatible FC board list
Model name SWD port SERIAL port remark
1) JXD 385 yes yes
2) JXD 388 yes yes
3) JXD 392 yes yes
4) WLtoys V212 yes yes
5) WLtoys V222 yes yes
6) WLtoys V262 yes yes From rev 03
7) WLtoys V272 yes no
8) WLtoys V333 yes yes
ç) SYMA X12 no no
10) UDI U839 no no
11) YI ZHAN X4 no no To be confirmed
12) Hubsan H107 yes no
More videos to come
SeByDocKy is offline Find More Posts by SeByDocKy
Old Nov 05, 2014, 06:29 AM
SeByDocKy's Avatar
Joined Dec 2012
Reserved for extra videos
DeviationTX Windows toolchain installation tutorial
DeviationTX toolchain installation for Windows system (35 min 40 sec)
If you want to add feature in the current "V2x2" protocol, can be useful
WLtoys V262 w/ bradwii
WLtoys V262 with Bradwii F/W (2 min 33 sec)
Old Nov 05, 2014, 06:35 AM
Joined Jan 2014
Thanks. I have all bought for this project, just never had any time to go though of the installation. Maybe your tutorials will give me the final push to do that.
mahagr is offline Find More Posts by mahagr
Old Nov 05, 2014, 06:38 AM
SeByDocKy's Avatar
Joined Dec 2012
The main objective.... of this tutorlal
Old Nov 05, 2014, 07:50 AM
United States, MD, Annapolis
Joined Jun 2013
Nice! Thanks for the post!
Waterbound is online now Find More Posts by Waterbound
Latest blog entry: Hubsan H107D Custom FPV Setup
Old Nov 05, 2014, 11:11 AM
I Void Warranties
goebish's Avatar
France, Aquitaine, Bordeaux
Joined Feb 2010
Cool, thanks for making a tutorial.
I'll keep this post as a placeholder on page 1 in case I've things to add later
goebish is offline Find More Posts by goebish
Old Nov 05, 2014, 11:22 AM
SeByDocKy's Avatar
Joined Dec 2012
You are the welcome
I will add also many other video/photos, especially the pinout for some bradwii compatible board I have and some demo flights from other bradwii users
You are free to add in your repo and for devationTX my so wanted feature To decrease to 250kbits, the speed rate of the V2x2
Old Nov 06, 2014, 01:16 AM
SeByDocKy's Avatar
Joined Dec 2012
Added 4 other bradwii FC compatible pinout in #1
Old Nov 06, 2014, 05:14 AM
ONCLEFLY's Avatar
France, IDF, Montlhéry
Joined Jun 2013
Yes, I am going to be able to put myself in it and understand. thank SEBY
ONCLEFLY is offline Find More Posts by ONCLEFLY
Old Nov 06, 2014, 06:49 AM
MassiveOverkill's Avatar
United States, FL, Melbourne
Joined Feb 2011
Thanks for this tutorial SeBy
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Old Nov 06, 2014, 07:09 AM
I Void Warranties
goebish's Avatar
Joined Feb 2010
Due to the recent FTDI driver drama, I wouldn't recommend using a ftdi usb to serial dongle (banggood have fake chips on the dongles they sell by the way, I checked myself).
Better use a CP2102 instead, no worry, they are 3.3V TTL level, and they're cheaper ! :
Old Nov 06, 2014, 07:35 AM
Joined Feb 2011
Those drivers were actually pulled. I just flashed a GPS unit this weekend using my fake FTDI adapter from Hobby King and it survived without issue.
Site Sponsor
Old Nov 06, 2014, 07:37 AM
SeByDocKy's Avatar
Joined Dec 2012
Thanks for the info . I will update #1 with your link
Old Nov 06, 2014, 07:40 AM
I Void Warranties
goebish's Avatar
Joined Feb 2010
You had no issue because an older version of the driver was already installed on your machine. It's still not clear what ftdi will do against fake chips in the next driver update, better safe than sorry and stop using this brand. I've been using CP2102 dongles for years, they are cheap and work very well, they're also win/linux/osx/android compatible...
Are you sure your dongle is using a fake chip ? I checked one that came with the HK Micro-X quad, it's detected as genuine.
I checked almost 10x FT232RL I have at home in various devices, only one has been detected as a fake, but that's enough for me, how can I know if I buy a real or a fake when I buy an end user product ?
Old Nov 06, 2014, 07:57 AM
hopeless newbie
Joined Oct 2014
+1
Since FTDI made it clear they don't want you to use products with fake FTDI chips, and they know how to detect these, you can bet that at some point in the future the fake equipment will again stop working. It may not get bricked next time, and just display a big fat "you have a fake" box on the screen, but you still won't be able to use it, which will be mighty annoying when it happens.
Another alternative is usb/serial dongles based on Prolific PL2303 - though these have been counterfeited as well in the past. Not that familiar with CP2012 but seems like every usb/serial chip has been plagued by fakes..
You can't really do anything to know you aren't buying a product with fake chips (could be a supplier's supplier's problem..) but you can avoid patronizing companies that willfully destroy your property (FTDI).
offbyone is offline Find More Posts by offbyone
Discussion Introducing BradWii - Open Source Multi-Copter Software bradquick Multirotor Electronics 729 Dec 20, 2014 08:54 AM
Discussion Bradwii on V202, V252, JD-385 victzh DIY Electronics 249 Nov 30, 2014 02:16 PM
Discussion Bradwii on Paris Air v2 Jdjuggler Multirotor Electronics 1 Jul 31, 2014 11:39 PM
Discussion Obama’s Forged Birth Certificate Brings Call For Revolution zeroback Life, The Universe, and Politics 97 Dec 30, 2013 10:46 AM
Discussion Stick ranges in BradWii Hooch180 Multirotor Electronics 0 Sep 06, 2013 04:26 AM
