Old May 08, 2012, 07:15 AM
Nethole is offline
Find More Posts by Nethole
Registered Lurker
Nethole's Avatar
Joined Aug 2004
which 'lead' goes from the hitex 4c to this 'all in one' balance board
I have a hitec 4x charger with a variety of batteries, I don't want to be continually disconnecting the various balance boards. I found this
http://www.hobbyking.com/hobbyking/s...HP_XH_EH_.html
But I'll still need the lead that goes from this all-in-one balance board to my charger. I think there are a variety of 'offshore branded' versions of the same hitec branded charger, but I don't know what the lead from the charger to the balance board is called to search for it.
Nethole is offline Find More Posts by Nethole
Old May 08, 2012, 07:18 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
It seems extremely odd that it would not already come with the lead that connects between the board and charger.
From the photo, it appears as though there are two options to connect to a charger. The two connectors on the edge of the board appear to be TP given that the pin pitch is typical TP spacing. The next connector is a 7S (8 pin) JST-XH.
Nearly all 'off-shore' generic chargers have JST-XH balance connectors. I seriously doubt that the X4 is any exception.
Given that this thing is not very straightforward, I would absolutely buzz it out with a continuity tester prior to connecting to a charger or a battery.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old May 08, 2012, 07:28 PM
NeveSSL is offline
Find More Posts by NeveSSL
So many UMs, so little money.
Nashville
Joined Jun 2008
You can use XH to XH or XH to TP either one. The spacing on the x4 is XH. The balance board you linked looks like it can take either XH or TP input.
Brandon
NeveSSL is offline Find More Posts by NeveSSL
Old May 08, 2012, 09:00 PM
Nethole is offline
Registered Lurker
Nethole's Avatar
Joined Aug 2004
Can you link a hobbyking item to do it?
New Product ***TBS CORE*** - The all-in-one FPV solution from the sheep that fly Enthlapy FPV Talk 23 Jul 19, 2012 09:29 AM
Sold Alternative FC2.0 board all in one board + 1 all in one mkbl board noppita Aircraft - Electric - Multirotor (FS/W) 1 Jan 29, 2012 10:48 PM
Discussion Using Paris Board. Must I cut all but one power wire from ESC? SplitFire Multirotor Talk 6 Jan 23, 2012 02:04 PM
Discussion All-in-one 2.4GHz receiver/brushlessESC/servos on one board (microbricks) Little-Acorn Scratchbuilt Indoor and Micro Models 3 Sep 25, 2011 07:14 PM
Sold Mixer/Gyro board all in one from Rotofly clone Pelanconi Flyer Aircraft - Electric - Helis (FS/W) 4 Aug 24, 2005 02:11 PM
