This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Jun 15, 2014, 08:10 PM
choochoo22 is offline
Find More Posts by choochoo22
Rick
United States, CA, Santa Clara
Joined Mar 2011
Originally Posted by quitcherbitchen View Post
Having an issue with mine. I switched it to another plane in which it was working perfectly and mounted right side up. The new plane it was mounted upside down, but the 3D configuration would move the ailerons only to maximum. Only the Ailerons. In 2 D everything was fine. I went to change the roll pot and tame it down to see if that was the trouble and then the unit went dead. No LED. I can't get it to go on again. All servos connected to it wouldn't respond. I disconnected the unit and put everything back the way it was and everything works except the Guardian. I suppose I will open a support ticket, but has anyone experienced this before?
Connect it to your PC and do a factory reset. If it won't respond to the PC, open a support ticket.
choochoo22 is offline Find More Posts by choochoo22
Old Jun 15, 2014, 08:25 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
+1 on the factory reset. Had to do it once on mine and once of my friend's.
voxel is offline Find More Posts by voxel
Old Jun 15, 2014, 09:12 PM
quitcherbitchen is online now
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Won't respond. I opened a ticket. Thanks
quitcherbitchen is online now Find More Posts by quitcherbitchen
Old Jun 16, 2014, 07:01 AM
stevo1957 is offline
Find More Posts by stevo1957
Australia, NSW, Baulkham Hills
Joined May 2004
Hi guys,
Apologies if the answer is elsewhere in this thread....
I have upgraded the firmware and am just wondering whether I need to redo any of the specific settings I was running under the old firmware version or whether these will just carry accross?
Cheers,
Steve
stevo1957 is offline Find More Posts by stevo1957
Old Jun 16, 2014, 08:13 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by stevo1957 View Post
Hi guys,
Cheers,
Steve
Steve,
Which level of firmware?
Bill
Prof100 is offline Find More Posts by Prof100
Old Jun 16, 2014, 02:21 PM
Ldm is online now
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
I think this is a great example of a book being needed called " Gyros for Dummies" and I will be the first in line to purchase the book !!
I am starting to remember why I always flew without them lol : ) , too many options I need to keep it simple for my adolescent child like mind that allows me to still purchase and play with expensive toys that the wifey approves !
Ldm is online now Find More Posts by Ldm
Old Jun 16, 2014, 02:31 PM
Joined Jul 2011
After mine failed on the bench I have a teensy bit of doubt about using it in the expensive plane I intended. As will all things there are failures. That I understand. Just need some reassurance that the odds are with me. Mine was mounted upside down and had the latest firmware. Just wondering if that could have contributed to the failure. 3D was just going crazy no matter what I did to the pots or switches. 2 D was fine as far as I could tell. Gain worked too. Maybe I should have reset it when I noticed the glitch. Lesson learned, but I am all ears to other suggestions.
Old Jun 16, 2014, 03:04 PM
CurrentDude is online now
Find More Posts by CurrentDude
Gravity gives sinking feeling
Joined Jun 2011
Did you set all control throws as per the instruction manual of the model manufacturer? This is important because your model will response to your stick controls and G will maintain whatever input signal you have given. So, imagine if you give more aileron throws than the manufacturer recommends then the model will become unstable.
See my vid below..... oops forgot to add the vid clip ;
Maiden after chaning ESC - 16 Aug 13 (0 min 55 sec)
My Storch was almost uncontrollable until I set the throws to the recommend
level and everything was fine after that.
Here is the second vid :
A low pass - Storch (much tamed) Part- 2 (0 min 28 sec)
HTH
Cheers
CurrentDude is online now Find More Posts by CurrentDude
Old Jun 16, 2014, 04:20 PM
Joined Jul 2011
Mine would just jam the ailerons to the left no matter what attitude the model was in at boot up. They never centered. It would also only do a twitch confirmation about every fourth time I plugged it in. All my throw were 100%. What is scary is it just died and with that all connections died with it. Had it been in the air it would have been a catastrophic failure. I probably should have reset it before mounting it upside down. Clean slate as a precaution.
Old Jun 16, 2014, 04:43 PM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Out-of-the-box Works
I've installed quite a few Guardians for modelers that had either a two-position switch for mode, or no extra channel for gain, etc. Other than cutting the AIL POT to about 70%, ELE POT to about 80%, and leaving the RUD POT at 100%, these installations have run with no changes to firmware, no PC connection, etc.
Are they getting the maximum stabilization? Probably not, but it has definitely saved their planes when switched into 2D.
Most of the discussion is centered around HH on or off, which mode is best, etc.; but if you follow choochoo22's User Guide (click on his avatar to find it), it will work pretty much out of the box. The only thinking required is to verify that the POTs are set to the correct direction and, again, the User Guide walks you through that. Once set, you can then do the "Level Set" gesture and forget about it.
The only stabilization device I have setup that is simpler is the far more expensive Bavarian Demon Cortex. As long as you are OK with upright (otherwise, PC access is required), just insert a bind plug, move the controls AIL: left/right, ELE: down/up, RUD: left/right, and that's it. With the bind plug, the correct stabilization direction is learned and, every time it is powered up, it memorizes the current TRIM settings. For $350, one would hope it would be simpler. There is no 2D mode to get you out of trouble, however.
Michael
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Jun 16, 2014, 05:35 PM
Joined May 2004
Originally Posted by Prof100 View Post
Steve,
Bill
Hi Bill,
I downloaded the 10.52 release update so the firmware is that attached to that release mate. V1.19
I decided against getting the beta release just yet.
Cheers,
Steve
Old Jun 16, 2014, 07:24 PM
Joined Jun 2011
It seems to me you may have a servo problem - suggest double check it and if that does solve the problem, then check if there are any lose connections. Push in all the plugs as much as you can, particularly ailerons since this where it seems you may have a problem. Failing that, I'd contact ET. They're pretty good at giving a prompt reply or may even take back any faulty G.
Let's know how you got on.
Cheers
Old Jun 16, 2014, 08:21 PM
Joined Jul 2011
Thanks CurrentDude, I sent the unit back for repair. All connections were solid., but the servo leads are long. Especially the ailerons. 72" wingspan. The fact that it didn't give a confirm twitch on start up should have been a red flag. If anyone else experiences this ground your plane. Once the unit dies so does all your servo controls that were connected to it.
Old Jun 16, 2014, 08:28 PM
Rick
Joined Mar 2011
Try the New User's Guide from here: http://www.rcgroups.com/forums/member.php?u=354219
It gives you a step-by-step using the current software along with some additional info and suggestions to make it easy to get started.
Old Jun 16, 2014, 09:21 PM
Rick
Joined Mar 2011
I don't recall any cases that could be confirmed to be a Guardian failing in flight. True, however, that it may be hard to verify since it would certainly lead to a crash. However, cases of Guardian being inop after a crash are rare, I don't recall any of those either. Those failures that have been reported here seem to be when updating firmware, DOA, or when moving it to another plane or generally messing with it. But it is electronic, and things can fail. And it takes a beating, which doesn't help. I would say the failure rate is no worse than a name brand receiver. In two years and maybe approaching 10 Guardians I have had two failures. One got wet, one in a bad crash ripped the USB off and did some other physical damage. The last one can't be updated now but it still works. In contrast, by the way, my first $270 NAZA the controller came out of the box dead.
Lack of a confirming twitch is not an indicator of failure or impending failure. It happens rather often, especially with the 1.24 beta firmware. Usually best results are obtained by letting it sit and finish booting for 10 sec or more, and toggling with a pause at each position.
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
