Old Jan 02, 2014, 12:28 AM
drjay's Avatar
Los Angeles, California
Joined Jul 2010
Build Log
Van Home-Built Shelf for Model Aircraft Transport
Like many RC airplane enthusiasts, I have ended up with more aircraft I would like to fly than space to easily transport them. Sure, I could take the wings off but with the extra wires that's usually a hassle.
Therefore I built a shelf for the back area of my Toyota Sienna minivan to provide more transport space.
Construction was simple. I used 1" PVC pipe, 3/16" thin wood laminate, some wood screws, zip ties and carpet rest all purchased at Home Depot:
Wood platform 51 " x 48" 3/16" thick laminate
1" PVC pipe and connectors:
4 x 10 foot 1" PVC lengths
8 T-connectors
4 corner connectors
1 X-connector
4 end caps
30 zip ties 11"
48" x 54" carpet rest
5 wood screws
Notes on connectors:
Each connector overlaps pipe by 2.4cm (15/16")
- T connectors are 3 ⅝" wide
- therefore Ts add 2" to length
Corners 2 ⅝" wide
- therefore corners add 1 " to length
Have Home Depot cut a 48" wide laminate to length at 51 "
Cut PVC pipe sections with a hacksaw as follows:
Sides (2)
2 x 9 "
2 x 13 ⅛"
Cross pieces (3)
2 x 22"
Long center pieces (1)
2 x 23"
Legs (4)
21" (back left leg cut down by 1 " due to floor panel)
Pipes go together without glue. Once the frame was together, I used 5 wood screws to affix the wood to the center T-connectors and the center cross connector after holes were predrilled easily.
Then I used the zip ties through larger pre-drilled holes to strap down the carpet remnant.
The PVC pipe caps were affixed to the legs which are removable for easy storage. I also added a few zip-ties and use a strap borrowed from another bag to carry the platform down to the parking structure in my building.
drjay is offline Find More Posts by drjay
Old Feb 24, 2014, 01:20 PM
3D Addict
Allinone's Avatar
United States, AL, Birmingham
Joined May 2013
Nice I can use this Thanks
Allinone is online now Find More Posts by Allinone
Latest blog entry: Tricopter "Candy Dropper"
Old May 19, 2014, 10:16 AM
The Hun in the Sun
vonJaerschky's Avatar
Canada, BC, Comox
Joined Nov 2003
I've often thought of doing something similar for my Grand Caravan. Nice to see such clean looking installation. Thanks for sharing it.
vonJaerschky is offline Find More Posts by vonJaerschky
Cool Home built and modifications thread! Teamsherman Australia 59 Mar 21, 2014 06:07 PM
Discussion Transport aircraft! francesco93 Electric Plane Talk 8 Dec 21, 2013 05:10 PM
Question Any recommendations for off-the-shelf landing gear for a custom aircraft? william_frane Electric Plane Talk 5 Feb 26, 2009 01:20 PM
Discussion Model Transport/Aircraft Carrier Tango Juliet The Builders Workshop 6 Sep 29, 2006 08:07 PM
Homing Devices for model aircraft. Al P Electric Plane Talk 12 Jun 17, 2001 07:44 AM
