Old Apr 20, 2014, 04:27 PM
-kno3-'s Avatar
Romania, Bucuresti, Bucharest
Joined Mar 2008
It looks just great!
-kno3- is offline Find More Posts by -kno3-
Old Apr 23, 2014, 03:47 PM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Update
Been on leave this week ( rebuilding suspension on my MG , and working in the evenings on the Rob Roy details.
I made up the break links and bars for the brakes , made the rear brackets and turned up the brake standard next up are the lever arms and last set of rods and ends.
Made up the rear bunker tank vent and piped up the sidetanks.
Piped up the crosshead pump and the hand pump (I am making a brass box to cover some of the crosshead pump pipework in the style of the lubricator on the other side.
Fitted the smokebox railing and when I figure out how I will fit the smokebox lamp bracket and lamp.
I keep finding little jobs to do all over the loco , but less of them now .
Got some brass sheet today to make up the removable roof and cab back sections for display .
More as and when.
dunc2504 is offline Find More Posts by dunc2504
Old Apr 23, 2014, 10:35 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Mg? :d
Kmot is online now Find More Posts by Kmot
Old Apr 24, 2014, 12:54 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Hi Tom.
Yes , I have an MGF ( had it for 12 years ) and use it rarely to zip round the country lanes in Somerset if the sun ever shines .
Did 739 miles last year .
Duncan.
Old Apr 24, 2014, 01:08 AM
Taking care of the pond.
MILLERTIME's Avatar
USA, CA, Fresno
Joined Apr 2004
Nice!
MILLERTIME is offline Find More Posts by MILLERTIME
Old Apr 26, 2014, 02:25 PM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Nearly There.
Hi.
Did some more work today .
Got a quote for 35 for cut round glass to fit in turned down 1" brass tube to make new windows for the cab
Then I had the idea of looking for watch glasses on ebay . Found hardlex glasses in anything from 16mm to 30mm for 3.20 each PERFECT.
made up the window frames from 3 seperate turnings , press fitted and bonded together they hold the glass perfectly .
Finished the fronts , working on the backs , they are more complex as I am drilling the frames for bars.
Made and fitted the dummy whistle to the cab (the real one is under the left running board) and fitted the lamp brackets and lamp to the smokebox .
Finished all the break system and set up the brakes (they are for show prety much as they are a bit weedy to stop the loco with the throttle open
Made up and fitted the crosshead pump cover .
Working on the cab steps , back windows and bunker rail now .
Dunc2504
Old Apr 27, 2014, 08:11 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I have never had a chance to see an MGF. The last ones here in the USA were MGC-GT's. It's a good looking car, that "F"!
Old Apr 30, 2014, 04:03 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
The MGF was pretty much the last sports car made by MG before they went bust and got taken over by the Chinese.
Mine has a Motorsport 190(Lotus version of the MG engine) all alloy engine with variable valve timing.
Made up the cab steps this weekend and bolted them onto the running boards.
Just a few jobs left to complete now .
I am going to rig up a gas burner to test it in steam .
I am not too keen on cleaning soot and tar out of the boiler after using coal . but may be tempted to try it later .
Old May 09, 2014, 04:13 PM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Completed
Finished off the Rob Roy today Well ! till I think of some other job to do
Drawing out the class case and getting the display track ready now .
I am working out how to fit a gas burner into the firebox to test her under steam before casing her up .
I still have all the running tools to make , like hand pump handle , coal shovel and special keys for gland tightening (which will live in a drawer in the display case eventually).
Finished off the bunker rails and the rear windows, so soon the search will be on for another project soon . But I need to find something a bit challenging and have no Idea what I want to build next yet.
Old May 10, 2014, 01:30 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
How about building a railroad around your yard for the Rob Roy to run on?
Old May 19, 2014, 05:21 PM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Very beautiful!
Jerome Morris is online now Find More Posts by Jerome Morris
Old May 28, 2014, 07:34 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Thanks.
Tom, Still working on the MG refurb and then I am starting work on another steam launch , hopefully powered by a Stuart D10 which I will build from castings.
